Hydro: Getting blank (black) screen in gazebo [closed]
asked 2013-08-05 12:54:12 -0500
rnunziata gravatar image
I am getting a random blank (black) screen in Gazebo 1.9 under VMWare running ROS Hydro. I have run groovy and other releases and did not have this issue until hydro. Has anyone else running hydro with Gazebo 1.9 under VMWare experienced this problem. Or any insights as to how to investigate this other then going to a duel boot.
edit retag flag offensive reopen merge delete
Closed for the following reason the question is answered, right answer was accepted by rnunziata
close date 2013-08-16 16:27:07.864303
answered 2013-08-05 13:55:29 -0500
updated 2013-08-06 16:10:41 -0500
This issue is related to VM I am using VMWare and when I turn off 3D acceleration in the VM the blank screen issue goes away.
This fixed my issue as well turn off 3d acceleration. Thanks.
gknight gravatar imagegknight ( 2013-08-15 11:51:32 -0500 )edit
Indeed, nice debugging on this! Encountered the same problem when running gazebo5. Seriously though, just a black screen without any debugging/warning messages is not the best way to go
bergercookie gravatar imagebergercookie ( 2016-10-27 15:14:31 -0500 )edit
answered 2013-08-05 14:41:30 -0500
Arn-O gravatar image
Just a guess ... always stop Gazebo with Ctrl+C from the console with which you launch it. I had a similar issue and that was the root cause.
Asked: 2013-08-05 12:54:12 -0500
Seen: 3,309 times
Last updated: Aug 06 '13
