My robot blows up when I launch the controllers [update 2]
EDIT2: I have forked the gazebo_ros_demos package to try a velocity control on the rrbot simple robot.
Here is the link to my repo: https://github.com/Arn-O/gazeborosdemos.git
I have changed something in the configuration files.
VelocityJointInterface and no longer EffortJointInterface:
<transmission name="tran2">
<joint name="joint2"/>
<actuator name="motor2">
<hardwareInterface>VelocityJointInterface</hardwareInterface>
</actuator>
</transmission>
\velocitycontrollers and no longer \effortcontrollers:
rrbot:
joint1_position_controller:
type: effort_controllers/JointPositionController
joint: joint1
pid: {p: 100.0, i: 0.01, d: 10.0}
joint2_velocity_controller:
type: velocity_controllers/JointVelocityController
joint: joint2
The robot does not explode with this configuration, but I do not have the expected effect. The joint2 is not animated.
EDIT: this is related to the velocity controller. I had another issue before the upgrade, see answer.
Hello.
I have upgraded the source code of the package required for the installation of Gazebo 1.9 and ROS, and now my robot blows up when I launch the controllers. (EDIT: it is fine without the velocity controllers).
Before the controllers:
After:
It looks like everything has collapsed to the origin point of my robot, like if there were no joints.
It was working fine before the update (expect the velocity controller). (EDIT: I had the usse described in the following answer).
Any idea?
Thx in advance!
EDIT: additional details.
Here is the definition of the elements of my robot related to this topic.
<joint name="wheel_joint_fl" type="continuous">
<axis xyz="0 1 0"/>
<limit effort="${wheel_joint_effort}" velocity="${wheel_joint_velocity}"/>
<origin xyz="${wheel_offset_x} ${wheel_offset_y} ${wheel_offset_z}" rpy="0 0 0"/>
<parent link="caster_link_fl"/>
<dynamics damping="${wheel_joint_damping}" friction="${wheel_joint_friction}"/>
<safety_controller k_velocity="${wheel_joint_safety_k_velocity}"/>
<child link="wheel_link_fl"/>
Definition of the transmission:
<transmission name="wheel_trans_fl">
<joint name="wheel_joint_fl"/>
<actuator name="wheel_motor_fl">
<hardwareInterface>EffortJointInterface</hardwareInterface>
<mechanicalReduction>${wheel_mechanical_reduction}</mechanicalReduction>
</actuator>
</transmission>
Launch file for the controllers:
<node name="controller_spawner" pkg="controller_manager"
type="spawner" respawn="false" output="screen"
ns="/youbot" args="--namespace=/youbot
wheel_joint_fl_velocity_controller
wheel_joint_fr_velocity_controller
wheel_joint_bl_velocity_controller
wheel_joint_br_velocity_controller
caster_joint_fl_position_controller
caster_joint_fr_position_controller
caster_joint_bl_position_controller
caster_joint_br_position_controller
arm_joint_1_position_controller
arm_joint_2_position_controller
arm_joint_3_position_controller
arm_joint_4_position_controller
arm_joint_5_position_controller
gripper_finger_joint_l_position_controller
gripper_finger_joint_r_position_controller" />
<!-- Load joint controller configurations from YAML file to parameter server -->
<rosparam file="$(find youbot_control)/config/youbot_control.yaml" command="load" />
And parameters of the controllers:
youbot:
wheel_joint_fl_velocity_controller:
type: effort_controllers/JointVelocityController
joint: wheel_joint_fl
wheel_joint_fr_velocity_controller:
joint: wheel_joint_fr
wheel_joint_bl_velocity_controller:
joint: wheel_joint_bl
wheel_joint_br_velocity_controller:
joint: wheel_joint_br
I have no error message when the bug is triggered. I do not know if there is a useful log somewhere.
I can create a simple rrbot like with a velocity controller to investigate the point (the tutorial has been very helpful).
Asked by Arn-O on 2013-08-07 09:36:15 UTC
Hi, I had similar problem in past and in my case the solution was to make PID values smaller.
Asked by Igor on 2013-08-13 09:29:06 UTC
ArnO , did this solve your problem?
Asked by nkoenig on 2013-09-15 19:48:58 UTC
At that time it did not solve the issue. My test repo is posted above, open to anyone willing to try. I'm a little bit short of time right now. I gonna have a look at it this evening (french hours).
Asked by Arn-O on 2013-09-17 02:59:38 UTC
I cloned your repo and found only a pendulum. Did you push in all of your local changes?
Asked by nkoenig on 2013-09-17 09:28:10 UTC
I will check this evening. I do not see my modification from the GitHub web interface.
Asked by Arn-O on 2013-09-17 09:37:23 UTC
Meanwhile, can we clarify something? The basic requirement is to control the velocity of a revolute joint. Do I have to use the plugin effort_controllers/joint_velocity_controller or the plugin velocity_controllers/joint_velocity_controllers?
Asked by Arn-O on 2013-09-17 09:49:00 UTC
effort_controllers/joint_velocity_controller will adjust effort (force), using a PID controller, applied to a joint(s) in order to reach a desired velocity. velocity_controllers/joint_velocity_controllers will pass the commanded joint velocity to the joint. The choice of controller depended on your robot.
Asked by nkoenig on 2013-09-17 10:31:07 UTC
I guess this is obvious when you are used to work with real robot. ;) The repo is updated. The idea is to use the effort to control the velocity of the joint1. The robot is the rrbot. With the configuration of the repo, I'm not able to start the controllers (error messages). EDIT: no error message (I have restarted the simulation) but the robot blows up.
Asked by Arn-O on 2013-09-17 15:51:06 UTC
Hi Am-O, did you manage to solve the problem?
Looks like I have the very same problems here.
See you Flo
Asked by frist on 2013-11-15 11:45:54 UTC
Yes, it was related to the inertia values. Some values can crash the robot, especially when they are too small.
Asked by Arn-O on 2013-11-17 16:04:04 UTC
Hi, I see. Would you mind posting a working configuration?
Thanks.
Asked by frist on 2013-11-17 16:05:59 UTC
On the same robot ?
Asked by Arn-O on 2013-11-17 16:14:32 UTC
On the same robot ?
Asked by Arn-O on 2013-11-17 16:15:03 UTC
Hi, yes, on the same robot. This is youbot, right. I'm basically trying to follow the 'quick start' guide at: https://github.com/micpalmia/youbot_ros_tools
Launching 'roslaunch youbot_gazebo youbot.launch' results in a shacking youbot that almost disintegrates.
Asked by frist on 2013-11-17 16:17:46 UTC
Thanks everybody for the input. I had the same problem. The model worked fine with every kind of controller except the effort_controllers/joint_velocity_controller. When I wanted to use it, my model kind of exploded or imploded in the simulation. I compute the inertia in the .urdf model automatically according to the mass and size of the links. Only by adjusting the mass the problem disappeared.
The Gazebo has a problem with inertia values or PID values too small or too large. So try to play around with those.
Asked by kumpakri on 2018-10-03 10:48:57 UTC
Can you explain what controllers you are running, and how you are running them. What version of ROS are you using? We'll also need to see the controllers.
Asked by nkoenig on 2013-08-08 10:44:22 UTC
Hello Nate. Gazebo = 1.9.5, ROS = hydro, and the controllers come from the source on GitHub. I hope that answer your question, there should be a way to have a detailed log, but I did not find it. I will update the above message with my tries on rrbot.
Asked by Arn-O on 2013-08-12 11:29:18 UTC
