DRCSIM doesn't start with roslaunch atlas_utils atlas.launch
Today, I updated all drcsim and gazebo and it's been 4 months since I used those. However, I couldn't start drcsim for some reason. It seems working at first, but it closes after launching the GUI. The below is the last part of the terminal msg. I think it's because of my GPU issue according to some previous questions. My laptops use radeon cards unfortunately. Please let me know how to get it work. I tried to change some drivers (Standard->proprietary->mesa utils), but no luck. I'm a very beginner and it'll be appreciated if someone can explain kindly to fix this issue. Thank you.
setting /run_id to e3b3dee4-0a24-11e3-9efe-701a04203eba
process[rosout-1]: started with pid [9145]
process[gazebo-2]: started with pid [9159]
process[atlas_robot_state_publisher-3]: started with pid [9164]
process[multisense_sl_robot_state_publisher-4]: started with pid [9178]
process[tf2_buffer_server-5]: started with pid [9204]
process[multisense_sl/camera/stereo_proc-6]: started with pid [9234]
Warning [gazebo_main.cc:64] escalating to SIGKILL on client
[gazebo-2] process has finished cleanly
log file: /home/wonyoung/.ros/log/e3b3dee4-0a24-11e3-9efe-701a04203eba/gazebo-2*.log
Asked by Wonyoung on 2013-08-21 01:00:00 UTC
I'm not sure what version of Gazebo you're using, but could you try installing Gazebo 1.9 and then run gazebo
If that fails, run gzserver
and gzclient
separately. Then generate a backtrace using gdb on whichever executable segafaults. Post the output of backtrace to this question.
Asked by nkoenig on 2013-09-15 18:44:33 UTC
