DRCSim ROS Version Moving Forward
Prior to VRC we were using ROS Fuerte with DRCSim. It looks now from the roadmap ( http://gazebosim.org/wiki/DRC/Roadmap ) that this is no longer supported.
Am I correct in interpreting the roadmap that in order to use the "drcsim" package we will have to ourselves be using ROS Groovy?
Does this mean we can build drcsim from source and still use fuerte? Or will we be required to use groovy?
Asked by jhoare on 2013-09-05 14:22:25 UTC
Update
After some more discussion, we will hold off switch from fuerte to groovy with 3.0.0, Instead, we'll make the move to Groovy+Precise with 3.1.0 (to be release soon after 3.0.0).
Original Post (Deprecated)
You should be able to build drcsim 3.0.x from source against Fuerte. But moving forward, we are catkinizing drcsim in 3.1.x, so it will no longer be feasible to support Fuerte given Fuerte does not have proper catkin dependencies.
Is there something that you are using which requires Fuerte support?
Asked by hsu on 2013-09-05 16:47:22 UTC
All of our development thus far has been in fuerte, and we were not planning on upgrading before DRC. However from the sounds of it we will need to, in order to continue using the simulator.
Asked by jhoare on 2013-09-06 08:23:28 UTC
Let me add my 0.2 cents.
Fuerte is now unsupported by upstream ROS, and although there are specific instructions to keep the system using drcsim-3.0 (still in Fuerte), I highly recommend move to Groovy (or newer) as soon as possible since starting with drcsim-3.2 new features won't be released under fuerte.
The problem for fuerte is that it lacks of fully catkin support and even compile drcsim from source will probably require you to modify the build system to back to rosbuild.
To avoid this migration problems and help with your decision about which platform to use, there is a draft of release plan sent today to gazebo mail list.
Asked by Jose Luis Rivero on 2013-10-28 14:48:36 UTC
