Not publishing Camera Info topic and I receive the follow message "WARNING: no messages received and simulated time is active. Is /clock being published?" <depthImageCameraInfoTopicName>
I'm working with Gazebo and kinect (libgazebo_ros_openni_kinect). The camera info topic are not been published, I got the "WARNING: no messages received and simulated time is active. Is /clock being published?"
Not published topics:
<cameraInfoTopicName>
compressedDepth
My kinect plugin have the following configuration:
<plugin name="camera" filename="libgazebo_ros_openni_kinect.so" >
  <cameraName>kinect_camera</cameraName>
  <frameName>camera_frame</frameName>
  <alwaysOn>true</alwaysOn>
  <updateRate>20</updateRate>
  <pointCloudCutoff>0.001</pointCloudCutoff>
  <imageTopicName>/camera/rgb/image_color</imageTopicName>
  <cameraInfoTopicName>/camera/rgb/camera_info</cameraInfoTopicName>
  <depthImageTopicName>/camera/depth_registered/image</depthImageTopicName>
  <pointCloudTopicName>/camera/depth_registered/points</pointCloudTopicName>
  <depthImageCameraInfoTopicName>/camera/depth_registered/camera_info</depthImageCameraInfoTopicName>
Asked by barcelosandre on 2013-09-10 17:36:15 UTC
Whats your output of "rostopic list" ?
To view the camera info topic, you should type "rostopic echo /kinect_camera/camera/depth_registered/camera_info" according to your configuration.
Asked by psei on 2013-09-13 03:07:52 UTC
I am struggling with the same problem. the outputs of my rostopic are "/gazebo/link_state" or alike, which I believe have nothing to do with the plugin.
Asked by simbazgb on 2014-08-12 12:41:06 UTC
What version of ROS and gazebo are you using?
Asked by nkoenig on 2014-08-13 10:02:10 UTC
I am using hydro with 1.9 gazebo. I tried turtlebot_gazebo package last night, and I can see those topics published. But I'd like to create another robot with sensor, but it doesn't work. I hacked kinect::model.sdf a bit, because kinect sdf doesn't contain a plugin as hokuyo does. Thanks for replying! I have problems probably because I am new.
Asked by simbazgb on 2014-08-13 18:08:28 UTC
Seems to me that add to urdf works well. I can run a kinect in gazebo well. When I replied days ago, I was trying to copy the tag to a sdf file. At this point, I may have to stick to urdf to get things work. Thanks for reply again, nkoenig.
Asked by simbazgb on 2014-08-16 17:01:14 UTC
Are you using sim time? In you launch file you should have:
Asked by nkoenig on 2013-09-14 20:21:43 UTC
