Gazebo Plugin for 6D velocity.. Error
asked 2013-10-04 14:12:37 -0500
espee gravatar image
updated 2013-10-06 10:58:10 -0500
nkoenig gravatar image
I got the following error suddenly in otherwise working code. the error doesnt show when a plugin is not included however thats not the solution.
Error [parser.cc:697] XML Element[plugin], child of element[link] not defined in SDF. Ignoring.[link]
Error [parser.cc:688] Error reading element <link>
Error [parser.cc:688] Error reading element <model>
Error [parser.cc:348] Unable to read element <sdf>
Error [parser.cc:299] parse as old deprecated model file failed.
Error [World.cc:1469] Unable to read sdf string
My gazebo plugin section is
<gazebo reference="base_footprint">
      <plugin name="3d_vel_controller" filename="libgazebo_ros3d.so">
        <robotNamespace>quad</robotNamespace>
        <odometryFrame>map</odometryFrame>
        <robotBaseFrame>base_footprint</robotBaseFrame>
        <odometryRate>20</odometryRate>
and my plugin looks as follows
#include "/home/saroj/gazebo_plugin/gazebo_ros3d.h"
#include <cmath>
namespace gazebo
  GazeboRos3DMove::GazeboRos3DMove() {}
  GazeboRos3DMove::~GazeboRos3DMove() {}
  // Load the controller
  void GazeboRos3DMove::Load(physics::ModelPtr parent,
      sdf::ElementPtr sdf)
    parent_ = parent;
    /* Parse parameters */
    robot_namespace_ = "";
    if (!sdf->HasElement("robotNamespace"))
      ROS_INFO("3DMovePlugin missing <robotNamespace>, "
          "defaults to \"%s\"", robot_namespace_.c_str());
    else
      robot_namespace_ =
        sdf->GetElement("robotNamespace")->Get<std::string>();
    command_topic_ = "cmd_vel";
    if (!sdf->HasElement("commandTopic"))
      ROS_WARN("3DMovePlugin (ns = %s) missing <commandTopic>, "
          robot_namespace_.c_str(), command_topic_.c_str());
    else
      command_topic_ = sdf->GetElement("commandTopic")->Get<std::string>();
    odometry_topic_ = "odom";
    if (!sdf->HasElement("odometryTopic"))
      ROS_WARN("3DMovePlugin (ns = %s) missing <odometryTopic>, "
          robot_namespace_.c_str(), odometry_topic_.c_str());
    else
      odometry_topic_ = sdf->GetElement("odometryTopic")->Get<std::string>();
    odometry_frame_ = "odom";
    if (!sdf->HasElement("odometryFrame"))
      ROS_WARN("3DMovePlugin (ns = %s) missing <odometryFrame>, "
          robot_namespace_.c_str(), odometry_frame_.c_str());
    else
      odometry_frame_ = sdf->GetElement("odometryFrame")->Get<std::string>();
    robot_base_frame_ = "base_footprint";
    if (!sdf->HasElement("robotBaseFrame"))
      ROS_WARN("3DMovePlugin (ns = %s) missing <robotBaseFrame>, "
          robot_namespace_.c_str(), robot_base_frame_.c_str());
    else
      robot_base_frame_ = sdf->GetElement("robotBaseFrame")->Get<std::string>();
    odometry_rate_ = 20.0;
    if (!sdf->HasElement("odometryRate"))
      ROS_WARN("3DMovePlugin (ns = %s) missing <odometryRate>, "
          "defaults to %f",
          robot_namespace_.c_str(), odometry_rate_);
    else
      odometry_rate_ = sdf->GetElement("odometryRate")->Get<double>();
    last_odom_publish_time_ = parent_->GetWorld()->GetSimTime();
    last_odom_pose_ = parent_->GetWorldPose();
    x_ = 0;
    y_ = 0;
    z_ = 0;
    rot_x_ = 0;
    rot_y_ = 0;
    rot_z_ = 0;
    alive_ = true;
    // Ensure that ROS has been initialized and subscribe to cmd_vel
    if (!ros::isInitialized())
      ROS_FATAL_STREAM("3DMovePlugin (ns = " << robot_namespace_
        << "). A ROS node for Gazebo has not been initialized, "
        << "unable to load plugin. Load the Gazebo system plugin "
        << "'libgazebo_ros_api_plugin.so' in the gazebo_ros package)");
      return;
    rosnode_.reset(new ros::NodeHandle(robot_namespace_));
    ROS_DEBUG("OCPlugin (%s) has started!",
    tf_prefix_ = tf::getPrefixParam(*rosnode_);
    transform_broadcaster_.reset(new tf::TransformBroadcaster());
    // subscribe to the odometry topic
    ros::SubscribeOptions so =
      ros::SubscribeOptions::create<geometry_msgs::Twist>(command_topic_, 1,
          boost::bind(&GazeboRos3DMove::cmdVelCallback, this, _1),
          ros::VoidPtr(), &queue_);
    vel_sub_ = rosnode_->subscribe(so);
    odometry_pub_ = rosnode_->advertise<nav_msgs::Odometry>(odometry_topic_, 1);
    // start custom queue for diff drive
    callback_queue_thread_ =
      boost::thread(boost::bind(&GazeboRos3DMove::QueueThread, this));
    // listen to the update event (broadcast every simulation iteration)
    update_connection_ =
      event::Events::ConnectWorldUpdateBegin(
          boost::bind(&GazeboRos3DMove::UpdateChild, this));
  // Update the controller
  void GazeboRos3DMove::UpdateChild()
    boost::mutex::scoped_lock scoped_lock(lock);
    math::Pose pose = parent_->GetWorldPose();
    float phi = pose.rot.GetRoll();
    float theta = pose.rot.GetPitch();
    float psi = pose.rot.GetYaw();
    parent_->SetLinearVel(math::Vector3 ...
(more)
answered 2013-10-06 11:01:49 -0500
This error:
says that a plugin cannot be attached to a link. You have to attach the plugin to a model.
Change your gazebo reference to:
<gazebo reference="model_name">
Thanks a lot. Its working now.
espee gravatar imageespee ( 2013-10-07 06:40:03 -0500 )edit
hi , is your transform_broadcaster running properly ? Actually i have also developed he same code as yours but it is showing error undefined symbol transform _broadcaster. I think it is a compilation error , but I am not able to solve it . Can you plz suggest me any solution .Thanks!
anonymous gravatar imageanonymous ( 2014-10-10 02:24:18 -0500 )edit
Asked: 2013-10-04 14:12:37 -0500
Seen: 507 times
Last updated: Oct 06 '13
