Operating PR2 in Gazebo 1.9 and Ros Groovy
I've been trying to vain to spawn and control a PR2 in Gazebo 1.9. I've tried Hydro and and Groovy but have had the most success with Groovy. I'm following these instructions to spawn a PR2 from xacro: http://gazebosim.org/wiki/Tutorials/1.9/Using_roslaunch_Files_to_Spawn_Models#Using_roslaunch_to_Spawn_URDF_Robots.
Among the many errors I am recieving is this one: Error [CameraPlugin.cc:46] CameraPlugin requires a CameraSensor. Msg It is a depth camera sensor
Anyone have this working or have an idea when a working version will be available?
Thanks in advance
Asked by ejs2119 on 2013-10-08 22:44:39 UTC
I can confirm this issue. I tried following the same tutorial to simulate the PR2 in Gazebo 1.9 und ROS Hydro. After loading the PR2 URDF from pr2_description onto the parameter server, and using spawn_urdf to spawn the robot I get several errors. Any news on the issue below?
Asked by Georg Bartels on 2013-11-05 05:39:59 UTC
I can confirm this issue. I tried following the same tutorial to simulate the PR2 in Gazebo 1.9 und ROS Hydro. After loading the PR2 URDF from pr2_description onto the parameter server, and using spawn_urdf to spawn the robot I get the following output:
Asked by Georg Bartels on 2013-11-05 05:40:00 UTC
Here is an issue to track this bug.
Asked by nkoenig on 2013-10-10 10:50:26 UTC
Thank you, Nate!
Asked by ejs2119 on 2013-10-10 20:50:02 UTC
I'm also using ROS Groovy, a PR2, and Gazebo, and it seems that I need to use 1.9 (as there are bad bugs seg. faulting in the default 1.5 installation). Is there any update on this issue? Is there any hope for us that must use Groovy?
Asked by Max on 2014-07-03 20:35:38 UTC
