libgazebo_player not working
Hi All,
I am trying to make Gazebo work with player and was going trying to go through the examples but every time I try open player I get the following error. Player has been working fine for me with stage so far. I am only having problems with Gazebo.
error : Failed to load plugin libgazeboplayer. error : libtool reports error: file not found error : plugin search path: /home/fahad/Spider:.:/usr/local/lib64/ error : failed to load plugin: libgazeboplayer error : failed to parse config file camera.cfg driver blocks
Gazebo does detect that player is installed. Any one else has encountered the same problem?
