Player with Gazebo: libprotobuf error messages.
I'm trying to control Pioneer2dx with Player, and visualize in Gazebo. I'm using Gazebo 1.9.1, Player 3.0.2.
I made the model of Pioneer2dx with Hokuyo laser on it in the Gazebo world. When I the Gazebo world file, and execute 'position2d.cfg', which is one of the example file. And used simple client 'playerv'. Here is my 'position2d.cfg' file.
driver
name "gazebo"
provides ["simulation:0"]
plugin "libgazebo_player"
# The name of a runnign Gazebo world, specified in a .world file
world_name "default"
driver
name "gazebo"
provides ["position2d:0"]
# This name must match the name of a model in the "default" world
model_name "pioneer2dx"
Controlling the pioneer with gui by 'command' menu was fine. The problem is, When I subscribe position2d:0, the terminal window which executed 'position2d.cfg' emits error messages repeatedly. The error message is following.
libprotobuf ERROR google/protobuf/messagelite.cc:123] Can't parse message of type "gazebo.msgs.PoseV" because it is missing required fields: pose[0].position, pose[0].orientation
And also, I couldn't see the laser output in playerv. This time I executed 'laser.cfg', and wanted to subscribe laser:0 with playerv. Then it also emitted following errors.
libprotobuf ERROR google/protobuf/wireformat.cc:1059] Encountered string containing invalid UTF-8 data while parsing protocol buffer. Strings must contain only UTF-8; use the 'bytes' type for raw bytes. libprotobuf ERROR google/protobuf/messagelite.cc:123] Can't parse message of type "gazebo.msgs.LaserScan" because it is missing required fields: anglemin, anglemax, anglestep, rangemin, rangemax, worldpose.position, world_pose.orientation
The error messages are the same when I use my own client program to set speed of Pioneer or read from robot. I think the position2d and laser error messages come from the same cause.
I have no idea where these error come from.. Any ideas?
Thanks in advance!! :)
Joon.
Asked by JOON on 2013-10-11 06:02:08 UTC
The Player interface in gazebo is out of date, you'll need the fixes in https://bitbucket.org/osrf/gazebo/pull-request/1324/update-to-player-interfaces/diff to fix it.
Asked by rmattes on 2014-12-04 16:34:57 UTC
I have a similar problem here. Can any one pitch in on this?
Asked by K. Zeng on 2014-11-14 15:08:51 UTC
