<sensor> elements in .urdf disappearing when converting to .sdf
Hello everyone,
I am working on the URDF description of the IIT COMAN robot, and I'm having some difficulties in inserting the gazebo force_torque sensor in my robot description.
Inserting the
In the .gazebo file
<gazebo reference="LElbj">
<cfmDamping>1</cfmDamping>
<provideFeedback>true</provideFeedback>
<sensor type="force_torque" name="LElbj_FT">
<always_on>true</always_on>
<update_rate>1000</update_rate>
In the .gazebo, after including the right xmlns:sensor in the
<sensor:force_torque name="LElbj_FT">
</sensor:force_torque>
In the .urdf
<joint name="RElbj" type="revolute">
<parent link="RShy"/>
<child link="RElb"/>
<origin xyz="0.0 0.0 -0.13519152999999998" rpy="0 0 0" />
<axis xyz="0 1 0" />
<limit velocity="4.0" effort="50" lower="-2.3562" upper="0.0" />
<sensor type="force_torque" name="Relbj_FT">
Obviously doing the same thing in the .sdf file works correctly (as shown in the force_torque_demo.world
example).
Any help would be greatly appreciated.
Asked by arocchi on 2013-10-13 13:05:03 UTC
The first syntax for your .gazebo
file is correct. Have you included the .gazebo
file in your .xacro
file?
I believe you can also directly insert
into you .urdf
file.
Asked by nkoenig on 2013-10-14 11:54:11 UTC
yes, the .gazebo is included in the .xacro file (coman.gazebo is included by coman_robot.urdf.xacro:
Asked by arocchi on 2013-10-14 12:04:00 UTC
Hi @nkoenig, It doesn't work. I think is a problem with the sensor tag within a joint because if I put only provideFeedback
It's added to the .sdf
. I'm working with gazebo 1.9.5
Asked by Francisco on 2014-06-05 08:50:21 UTC
it is a bug in sdformat which I reported some time ago, still not fixed. https://bitbucket.org/osrf/sdformat/issue/38/force_torque-sensors-not-handled-by
Asked by arocchi on 2014-06-06 03:47:02 UTC
Hi @arocchi, did you solve it?
Asked by Francisco on 2014-06-05 08:52:14 UTC
