Working code of controlling Gazebo with Player
Hi all,
I understand that most of you are using ROS but I am trying to do some simple joint manipulations using Player. I have been trying to work with the available examples but at the moment I am having a lot of errors. By any chance any one has a working example for Player code with Gazebo. I am trying to compile the simple.c program. I think the main problem is libgazebo.a and gazebo.h are not getting installed on the system. I will try to upload the exact errors. Thanks.
I'm not using player, but have in the past.. what examples are you referring to? And what type errors are you receiving? (Could you update your question with this information?)
Ok i have added some detail but I will try to add more details.
