When exited gazebo via the quit menu the system does not shutdown completely.
When exited gazebo via the quit menu the system does not shut down completely. It does not seem to matter how long I wait for shutdown to complete. If restated then a error occurs on the next launch in many instances unless I kill all related processes.
roslaunch rrbot_gazebo rrbot.launch
... logging to /home/viki/.ros/log/b02b5aa8-3d90-11e3-b25e-28cfe95d78b1/roslaunch-viki-4282.log
Press Ctrl-C to interrupt
started roslaunch server http://viki:51345/
SUMMARY
PARAMETERS
* /rosdistro
* /rosversion
* /use_sim_time
NODES
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
auto-starting new master
process[master]: started with pid [4296]
setting /run_id to b02b5aa8-3d90-11e3-b25e-28cfe95d78b1
process[rosout-1]: started with pid [4309]
process[gazebo-2]: started with pid [4323]
process[gazebo_gui-3]: started with pid [4328]
Gazebo multi-robot simulator, version 1.9.1
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.[ INFO] [1382717739.929014641]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1382717739.929873735]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
Msg Publicized address: 192.168.1.80
[ INFO] [1382717741.900888129]: Loading gazebo_ros_control plugin
[ INFO] [1382717741.901100554]: Starting gazebo_ros_control plugin in namespace: /rrbot
[ INFO] [1382717741.902397165]: gazebo_ros_control plugin is waiting for model URDF in parameter [robot_description] on the ROS param server.
[gazebo_gui-3] process has finished cleanly
log file: /home/viki/.ros/log/b02b5aa8-3d90-11e3-b25e-28cfe95d78b1/gazebo_gui-3*.log
^C[gazebo-2] killing on exit
[gazebo-2] escalating to SIGTERM
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
Asked by rnunziata on 2013-10-25 11:22:55 UTC
What version of ROS and gazebo are you using?
Asked by nkoenig on 2013-10-25 12:37:33 UTC
Gazebo 1.9 and any upgrades
Asked by rnunziata on 2013-10-26 07:08:57 UTC
This is currently being worked on. Stay tuned.
Asked by nkoenig on 2013-11-07 18:05:31 UTC
I am running into the same problem. When I exit Gazebo, it usually stalls and eventually prints "escalating to SIGKILL on server" before exiting. This is a problem because it's preventing the destructor of a plugin from being called. I am using Gazebo 2.2.2 and ROS Groovy on Ubuntu 12.04.
Asked by liangfok on 2014-04-15 14:02:40 UTC
Can you try running Gazebo standalone (no plugins, no ROS)? In this use-case do the problems still exist?
Asked by nkoenig on 2014-04-15 18:01:46 UTC
I am new to gazebo, ran into the same error today. I know this question is a bit old but any updates on this? I'll love a solution. Thanks
Asked by pr_db on 2020-11-23 09:02:55 UTC
