Tons of Errors building Gazebo on Ubuntu 13.10
asked 2013-11-05 08:54:29 -0600
aqiruse gravatar image
updated 2013-11-06 06:59:11 -0600
Jose Luis Rivero gravatar image
When I try to build gazebo, and I have been trying for 2 hours now. I receive many errors. I have installed every boost library i can think of, ogre, sdf, etc, etc etc. And it still will not compile. It still tells me I need boost. Boost is already installed. The output of cmake reads:
:~/Code/gazebo_maps/build$ cmake ../
-- Gazebo version 2.0.0
-- Found CPack generators: DEB
-- High memory tests: enabled
====== Finding 3rd Party Packages ======
-- Operating system is Linux
-- checking for module 'freeimage>='
Must specify package names on the command line
--   package 'freeimage>=' not found
--   freeimage.pc not found, trying freeimage_include_dir and freeimage_library_dir flags.
--   Looking for FreeImage.h - found
--   Looking for libfreeimage - found
-- checking for module 'libprofiler'
--   package 'libprofiler' not found
-- Looking for libprofiler - not found
-- checking for module 'libtcmalloc'
--   package 'libtcmalloc' not found
-- Looking for libtcmalloc - not found
-- Looking for CEGUI, found
-- Looking for CEGUI-OGRE, found
CMake Warning at cmake/SearchForStuff.cmake:130 (find_package):
  By not providing "FindSimbody.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Simbody", but
  CMake did not find one.
  Could not find a package configuration file provided by "Simbody" with any
  of the following names:
    SimbodyConfig.cmake
    simbody-config.cmake
  Add the installation prefix of "Simbody" to CMAKE_PREFIX_PATH or set
  "Simbody_DIR" to a directory containing one of the above files.  If
  "Simbody" provides a separate development package or SDK, be sure it has
  been installed.
Call Stack (most recent call first):
  CMakeLists.txt:149 (include)
--  Simbody not found, for simbody physics engine option, please install libsimbody-dev.
-- Looking for tinyxml.h - found
-- Looking for libtar.h - found
Package OGRE was not found in the pkg-config search path.
Perhaps you should add the directory containing `OGRE.pc'
to the PKG_CONFIG_PATH environment variable
No package 'OGRE' found
CMake Error at cmake/SearchForStuff.cmake:187 (string):
  string sub-command REPLACE requires at least four arguments.
-- checking for module 'OGRE-Overlay'
--   package 'OGRE-Overlay' not found
--  Failed to find OGRE's plugin directory.  The build will succeed, but gazebo will likely fail to run.
-- checking for module 'libswscale'
--   package 'libswscale' not found
--  libswscale not found. Audio-video capabilities will be disabled.
-- checking for module 'libavformat'
--   package 'libavformat' not found
--  libavformat not found. Audio-video capabilities will be disabled.
-- checking for module 'libavcodec'
--   package 'libavcodec' not found
--  libavcodec not found. Audio-video capabilities will be disabled.
-- checking for modules 'playercore>=3.0;playerc++'
--   package 'playercore>=3.0' not found
--   package 'playerc++' not found
--  Player not found, gazebo plugin for player will not be built.
-- checking for module 'gts'
--   package 'gts' not found
--  GNU Triangulation Surface library not found - Gazebo will not have CSG support.
-- Boost version: 1.53.0
CMake Error at /usr/share/cmake-2.8/Modules/FindBoost.cmake:1126 (message):
  Unable to find the requested Boost libraries.
  Boost include path: /usr/include
  The following Boost libraries could not be found:
      boost_signals
      boost_system
      boost_filesystem
      boost_program_options
      boost_regex
      boost_iostreams
  Some (but not all) of the ...
(more)
It also can't find ogre. Can you paste the output of the following commands to see which debs you have installed? `dpkg -l | grep libogre` and `dpkg -l | grep libboost`
scpeters gravatar imagescpeters ( 2013-11-05 18:12:25 -0600 )edit
dev@dev-700Z7C:~$ dpkg -l | grep libogre ii libogre-1.7.4:amd64 1.7.4+dfsg1-7 amd64 3D Object-Oriented Graphics Rendering Engine (libraries) ii libogre-1.8.0:amd64 1.8.1+dfsg-0ubuntu1 amd64 3D Object-Oriented Graphics Rendering Engine (libraries) dev@dev-700Z7C:~$ dpkg -l | grep libboost ii libboost-all-dev 1.53.0.0ubuntu2 amd64 Boost
aqiruse gravatar imageaqiruse ( 2013-11-05 19:41:04 -0600 )edit
Well they are definitely installed. How about your environment variables? Output of env
scpeters gravatar imagescpeters ( 2013-11-05 20:20:02 -0600 )edit
Below is the environment variables. I am not sure what to be looking for in them though.
aqiruse gravatar imageaqiruse ( 2013-11-05 21:04:50 -0600 )edit
answered 2013-11-05 19:23:19 -0600
By any chance, did you follow the from source installation guide?
Yes I did, the output of it at the bottom of the other answer I just posted.
aqiruse gravatar imageaqiruse ( 2013-11-05 20:00:28 -0600 )edit
Thanks for the information. All looks ok to me. Could you please try to remove the build/ directory completely, create it again and run cmake ..?
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-11-06 07:05:56 -0600 )edit
I deleted the entire directory after performing a custom build of simbody, and performing the install command nkoenig gave. When I did that, and redownloaded the code, cmake completed without errors. I am in the process of building it now.
aqiruse gravatar imageaqiruse ( 2013-11-06 11:41:22 -0600 )edit
I was able to compile the code, however I had some trouble running it after the install. The path would be /usr/local/lib for the libgazebo* librarys i thought but instead it is /usr/local/lib/x86_64-linux-gnu/ on my system. Once I figured that out using find -name "libgazebo*" and corrected the bashrc I am able to launch gazebo now. Next comes ROS hookup.
aqiruse gravatar imageaqiruse ( 2013-11-07 02:29:34 -0600 )edit
Perfect, good luck. Could you mark this thread as solved clicking on the check button?
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2013-11-07 08:35:54 -0600 )edit
answered 2013-11-06 11:22:34 -0600
nkoenig gravatar image
Your sudo apt-get install did not work. I don't believe libsimbody-dev has been released for saucy.
Try this command:
sudo apt-get install build-essential libtinyxml-dev libboost-all-dev cmake mercurial pkg-config libprotoc-dev libprotobuf-dev protobuf-compiler libqt4-dev libtar-dev libcurl4-openssl-dev libcegui-mk2-dev libopenal-dev libtbb-dev libswscale-dev libavformat-dev libavcodec-dev libogre-1.8-dev libgts-dev libltdl3-dev playerc++ libxml2-dev libfreeimage-dev freeglut3-dev
That command succeeded.
aqiruse gravatar imageaqiruse ( 2013-11-06 11:38:56 -0600 )edit
Asked: 2013-11-05 08:54:29 -0600
Seen: 2,152 times
Last updated: Nov 06 '13
