Building Gazebo from Source and still having ROS Integration
There is a set of FAQ at http://gazebosim.org/wiki/Install/GazeboandROS which talks about integration of Gazebo and ROS. However, for my purposes, I am required to be able to build Gazebo frequently and make changes to it, while also still using ROS. I am using Ubuntu 13.10 and have downloaded the source code for Gazebo, made some changes, and built it, but now need to integrate ROS. How might I go about doing such a thing?
Asked by aqiruse on 2013-11-07 04:01:09 UTC
You'll need to build gazebo_ros_packages
from source.
It might be easiest to create a catkin workspace. Add gazebo_ros_packages
to the workspace along with and of your own ROS code.
Asked by nkoenig on 2013-11-07 16:01:52 UTC
Well, this will be harder then i thought. I am unable to install catkin_init_workspace. So I posted on answers.ros.org and will await an answer.
Asked by aqiruse on 2013-11-08 13:55:07 UTC
