Robot initial configuration
Hi, is possible to change the robot initial configuration specifying the joint values?
Asked by Enrico Mingo on 2013-11-22 09:59:15 UTC
No one has this problem?
Asked by Enrico Mingo on 2013-12-26 10:17:07 UTC
Hello, i do have the same problem. I want to spawn the UR5 in an initial pose. Is this obsolet for you? Did you solve it?
Asked by J_Schaefer on 2016-07-19 04:21:50 UTC
I now have exactly the same problem. In my case the UR5 robot's 'home position' is defined as (0, -PI/2, 0, -PI/2, 0, 0). I have to initialize the SDF model in this home position, otherwise there will be collisions etc.
Would it be possible to add a
I created a proposal to keep track of this feature request.
Asked by ahb on 2014-02-26 03:24:29 UTC
Hi, why don't you write a simple plugin and set the position of the joints during the load? In my opinion it may solve your problem
Asked by Andrea on 2014-02-28 13:32:14 UTC
Copy&Paste from the proposal: "My proposal is to have a "
Asked by ahb on 2014-03-02 07:57:04 UTC
Ok, I undestand what you proposed, but I tried to solve the problem. I mean, the feature is not implemented yet, therefore a workaround is needed at the moment. Obviously when the feature is available I do not see why he should not use it ;)
Asked by Andrea on 2014-03-04 11:30:33 UTC
