After version 1.8.0 (currently 2.1.0) dynamically created joints act unnatural [Resolved]
I am creating dynamically joints between multiple spheres, by connecting all spheres to a center one. This feature stopped working after version 1.8.0, the joints started acting very unnatural, spheres exploding and stuff. I tried many ways to change parameters when creating the joints, however without any significant changes.
Here is the function used in creating the joints:
void DynamicJointPlugin::CreateDynamicJoint(
physics::LinkPtr _parent_link, physics::LinkPtr _child_link)
physics::JointPtr joint;
math::Vector3 axis;
// for axis multiple examples tried
axis = math::Vector3(1,0,0);
joint = world->GetPhysicsEngine()->CreateJoint(
"revolute", this->liquidModel);
// switched attach order as well
joint->Attach(_parent_link, _child_link);
// for anchor also tried different values, including a default math::Pose
joint->Load(_parent_link, _child_link, _child_link->GetWorldPose());
// tried it with multiple values, even commented out
joint->SetAxis(0, axis);
joint->SetHighStop(0, M_PI);
joint->SetLowStop(0, -M_PI);
// tried with/without
joint->Init();
// tried it commented out and with several other values (no significant changes occured)
this->pancakeJoints.back()->SetAttribute("stop_cfm", 0, this->stop_cfm);
this->pancakeJoints.back()->SetAttribute("stop_erp", 0, this->stop_erp);
this->pancakeJoints.back()->SetAttribute("fudge_factor", 0, this->fudge_factor);
this->pancakeJoints.back()->SetAttribute("cfm", 0, this->cfm);
this->pancakeJoints.back()->SetAttribute("erp", 0, this->erp);
The sdf of the model including all the spheres are loaded as well dynamically and it looks like this:
<?xml version='1.0'?>
<sdf version='1.4'>
<model name='liquid_spheres'>
<static>false</static>
<pose>0.2 0.1 1 0 0 0 </pose>
<link name='sphere_link_0'>
<self_collide>true</self_collide>
<pose>0 0 0 0 0 0</pose>
<pose> 0 0 0 0 0 0 </pose>
<ixx>0.000102</ixx>
<iyy>0.000102</iyy>
<izz>0.000102</izz>
<mass>0.001</mass>
<collision name='collision_0'>
<sphere>
<radius>0.005</radius>
</sphere>
<surface>
<friction>
<ode>
<mu>0.85</mu>
<mu2>0.85</mu2>
<fdir1>0.0 0.0 0.0</fdir1>
<slip1>1</slip1>
<slip2>1</slip2>
</ode>
</friction>
<bounce>
<threshold>10000.0</threshold>
</bounce>
<contact>
<ode>
<soft_cfm>0.58</soft_cfm>
<soft_erp>0.58</soft_erp>
<kp>100</kp>
<kd>1</kd>
<max_vel>100.0</max_vel>
<min_depth>0.001</min_depth>
</ode>
</contact>
</surface>
<visual name='sphere_visual_0'>
<sphere>
</sphere>
<script>
<name>Gazebo/Red</name>
</script>
Videos about the behavior: 50 spheres, joints created between all of them and a middle sphere, joints created consecutively:
https://vimeo.com/80458794
50 spheres, joints created, iteratively, only acts weird after it has been touched by another item:
https://vimeo.com/80457826
3 spheres:
https://vimeo.com/80457823
https://vimeo.com/80457822
2 spheres:
https://vimeo.com/80457820
Thanks, Andrei
UPDATE
Problem doesn't appear in newer versions.
Asked by AndreiHaidu on 2013-11-27 09:13:25 UTC
