Changing colors of an object without using visual / system plugins
Is there a way to dynamically change the color of an object using a world / model plugin?
Thanks, Andrei
Asked by AndreiHaidu on 2013-11-27 09:18:07 UTC
I haven't tried this, but it should be possible by publishing a Visual msg on the ~/visual topic. Make sure the name in the message is the same as the visual you want to change. Also specify the material in the message.
Asked by nkoenig on 2013-11-27 13:14:06 UTC
