The strange thing when I add PR2 on empty gazebo scene
I use ROS groovy on ubuntu 12.10 64 bits.
I can't upload the picture of gazebo.
Does anyone help me how to upload?
The message I got is:
sam@sam:~/code/ros_groovy/src$ roslaunch gazebo_worlds empty_world.launch
... logging to /home/sam/.ros/log/c6d55390-5e8c-11e3-ab5a-20cf30a23845/roslaunch-sam-1437.log
Press Ctrl-C to interrupt
started roslaunch server http://sam:56416/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
    gazebo (gazebo/gazebo)
    gazebo_gui (gazebo/gui)
core service [/rosout] found
process[gazebo-1]: started with pid [1455]
process[gazebo_gui-2]: started with pid [1460]
Gazebo multi-robot simulator, version 1.5.0
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Msg Waiting for master
[ INFO] [1386660366.853533724]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
Msg Publicized address: 192.168.0.101
[ INFO] [1386660368.375304123, 0.023000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1386660368.404689916, 0.051000000]: Starting to spin physics dynamic reconfigure node...
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/camera/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/camera]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/cinder_block_2/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/cinder_block_2]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/construction_barrel/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/construction_barrel]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/create/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/create]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/cube_20k/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/cube_20k]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/double_pendulum_with_base/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/double_pendulum_with_base]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_2x4/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_2x4]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_2x6/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_2x6]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_4x4x20/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_4x4x20]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_4x4x40/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_4x4x40]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_angled_barrier_135/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_angled_barrier_135]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_angled_barrier_45/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_angled_barrier_45]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/drc_practice_ball_valve/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/drc_practice_ball_valve]
Warning [ModelDatabase.cc:179] Unable to connect to model database using [http://gazebosim.org/models/grey_wall/model.config]. Only locally installed models will be available.
Error [ModelDatabase.cc:344] Unable to get model name[http://gazebosim.org/models/grey_wall]
Warning [Publisher.cc:130] Queue limit reached for topic /gazebo/default/pose/info, deleting message (only this warning is printed to the console, see the ~/.gazebo/gzserver.log and ~/.gazebo/gzclient.log files for future warnings).
Asked by sam on 2013-12-12 22:17:46 UTC
