Using projectors in Gazebo 1.9 + ROS Hydro?
I was trying to create an example projector project to demonstrate some problems I was having with projector poses, but couldn't get the texture to appear at all, there is just what appears a default error image with yellow diagonal bars on black.
example image on github, (don't have karma to upload and providing a link isn't working)
This is the xacro file responsible:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="projector_test">
<link name="world"/>
<link name="link_projector">
<visual>
<cylinder length="0.2" radius="0.05" />
<mass value="1.0"/>
<inertia ixx="1.0" ixy="0.0" ixz="0.0" iyy="1.0" iyz="0.0" izz="1.0" />
<joint name="joint_projector" type="fixed">
<origin xyz="0 0 2.0" rpy="0.0 0 0" />
<parent link="world" />
<child link="link_projector" />
<gazebo reference="link_projector">
<projector name="projector_test1">
<pose>0 0 0 0 0 0</pose>
<!-- this isn't getting loaded properly -->
<texture>$(find projector_test)/urdf/test_pattern.png</texture>
<!--texture>test_pattern.png</texture-->
<fov>0.6</fov>
<near_clip>0.1</near_clip>
<far_clip>10.0</far_clip>
</projector>
This is from projector test, there is also a launch file there and catkin package.xml and CMake files, roslaunch projector_test projector_test.launch launches it.
In another project I was able to make projectors work somewhat, I had the png in a meshes dir and I think that because another resource was loaded from the same directory (and which had a full path) the png was able to be found.
Asked by Lucas Walter on 2014-01-13 19:06:03 UTC
Could you solve this problem? I'm facing the same problem and this happens even with the full path of the image. I'm using Gazebo version 7.14.0 + ROS Kinetic. Edit: I could not find the answer yet, but experimenting other codes I've found out that replacing the texture tag by the following one actually replaces the yellow diagonal bars error image:stereo_projection_pattern_high_res_red.png
Also, some images from /usr/share/gazebo-7/media/materials/textures work, others not
Asked by hbaqueiro on 2018-09-06 08:39:40 UTC
