disabling connect to server at launch
Hi Gazebo server always try to connect to server at launch time. and terminates if it do not gets response in 30 seconds. Is there any appropriate way to avoid this behaviour? Can all models be downloaded as a tarball and accessed locally by the gazebo server?
rgds nitin
Asked by nitin on 2014-01-22 19:54:57 UTC
All models can be downloaded from repository via hg clone https://bitbucket.org/osrf/gazebo_models
Asked by nitin on 2014-01-22 20:05:50 UTC
According to user guide ( http://gazebosim.org/user_guide/started__models__database.html) Gazebo uses two environment variables to find model databases.
 GAZEBO_MODEL_DATABASE_URI
 This is a URI that points to an online
 model database. The default value is
 http://gazebosim.org/models
 GAZEBO_MODEL_PATH
 This is a colon-separated list of  local paths that Gazebo should search  for databases.
  Each path should point to the directory that contains the  database config.
  These paths take  precedence over the online URI database.
By modification of these variables, this behavior can be avoided.
Asked by nitin on 2014-01-22 20:23:00 UTC
