gazebo_ros_imu always sets frame_id to base_link
I'm running Gazebo 1.9.2 with the following URDF file:
<?xml version="1.0"?>
<!-- test.urdf -->
<robot name="robot">
  <link name="base_link">
    <visual>
        <box size="0.01 0.01 0.01"/>
    <collision>
      <mass value="0.001"/>
      <inertia ixx="0.000000017" ixy="0" ixz="0" iyy="0.000000017" iyz="0"
               izz="0.000000017"/>
    <material>Gazebo/White</material>
  <link name="imu">
    <visual>
        <box size="0.05 0.05 0.05"/>
    <collision>
               izz="0.000000017"/>
  <gazebo reference="imu">
  <joint name="base_link_to_imu" type="fixed">
    <parent link="base_link"/>
    <child link="imu"/>
    <origin xyz="0 0 1"/>
  <gazebo>
    <plugin name="imu" filename="libgazebo_ros_imu.so">
      <bodyName>imu</bodyName>
      <topicName>imu/data</topicName>
      <serviceName>imu/calibrate</serviceName>
</robot>
When I run Gazebo, the messages published to imu/data have "base_link" in their header.frame_id fields, when the field should contain "imu". I replaced the plugin's <gazebo> line with <gazebo reference="imu">, but that caused a syntax error:
    Error [parser.cc:697] XML Element[plugin], child of element[link] not defined in SDF. Ignoring.[link]
    Error [parser.cc:688] Error reading element
    Error [parser.cc:348] Unable to read element
    Error [parser.cc:299] parse as old deprecated model file failed.
    Error [World.cc:1469] Unable to read sdf string
I added a ROS_INFO_STREAM() call to gazebo_ros_imu.cpp:
    if (!this->sdf->HasElement("bodyName"))
      ROS_FATAL("imu plugin missing , cannot proceed");
      return;
    else
      this->link_name_ = this->sdf->Get("bodyName");
    ROS_INFO_STREAM("this->link_name_ = " << this->link_name_); // This prints "base_link".
This code confirmed that the plugin is getting "base_link" as the value of the bodyName parameter. Am I specifying the IMU plugin incorrectly in the URDF file?
Asked by Jim Rothrock on 2014-01-25 15:46:22 UTC
