Fixing location of a sub-model
I currently have a model of a tire, and a seperate sub-model for the holes used for mounting. As shown in the following images, these two meshes are not rigidly connected in any way. I have also included the SDF for the wheel.
(Unfortunately, I cannot upload images. Here's a Link)
How can I join these two objects so that they never separate?
Wheel SDF
<?xml version='1.0'?>
<sdf version="1.4">
<model name="Wheel">
<pose>0 0 0 0.0 0.0 0.0 </pose>
<static>false</static>
<uri> model://Wheel_Hub </uri>
<name> Hub </name>
<pose> 0.1 0.0 0.0 0.0 0.0 0.0 </pose>
<link name="body">
<mass>5.0</mass>
<ixx>0.555</ixx>
<ixy>0.000</ixy>
<ixz>0.000</ixz>
<iyy>0.976</iyy>
<iyz>0.000</iyz>
<izz>0.555</izz>
<mesh><uri>model://Wheel/meshes/wheel.dae</uri></mesh>
<emissive> 1 1 1 1 </emissive>
<surface>
<bounce>
<restitution_coefficient> 0.4 </restitution_coefficient>
<threshold> 0 </threshold>
</bounce>
<contact>
<ode>
<max_vel>10</max_vel>
</ode>
</contact>
</surface>
Hub SDF
<sdf version="1.4">
<model name="Wheel_Hub">
<link name="body">
<mass>0.1</mass>
<ixx>1</ixx>
<ixy>0.000</ixy>
<ixz>0.000</ixz>
<iyy>1</iyy>
<iyz>0.000</iyz>
<izz>1</izz>
<mesh><uri>model://Wheel_Hub/meshes/wheel_hub.dae</uri></mesh>
Asked by Peaches491 on 2014-01-28 14:44:29 UTC
You'll have to create a joint between the wheel and the hub. Along the lines of:
<joint name="hub_fixed" type="revolute">
<parent>Wheel_Hub::body</parent>
<child>body</child>
<axis>
<xyz>0 0 1</xyz>
<limit>
<upper>0</upper>
<lower>0</lower>
</limit>
</axis>
Put that in the Wheel model, after the </link>
and before the </model>
Asked by nkoenig on 2014-01-29 00:01:13 UTC
