gazebo server terminate on starting
i am getting a very strange response for Gazebo server. My setup is Gazebo 1.9.0 + Ubuntu12.04 + ROS Hydro. I was able to run gzclient and gzserver independently.
I was running through tutorial http://gazebosim.org/wiki/Tutorials/1.9/UsingroslaunchFilestoSpawn_Models. Server exits with error code 134.
There was other errors fro plugin loading "Failed to load plugin libhuskygazeboplugin.so". No such File or Directory. This was reported consequent to manually adding Clearpath Husky from local modelbase in the world. To solve it, I updated GAZEBOPLUGINPATH in /usr/share/gazebo-1.9/setup.sh to include ros-hydro gazebo-plugins path. After that I am getting following error:
Terminate after throwing an instance of boost::exception_detail::clone_impl<boost_exception_detail::error_info_injection<boost::bad_lexical_cast> >
Source type can not be interpreted as target
Even after reverting setup.sh to previous values, I am still stuck with this error! Not able to debug this problem.
Thanks nitin
Asked by nitin on 2014-01-29 01:27:08 UTC
I've seen this error before in gazebo. Could you please post what command are you running?
Asked by Jose Luis Rivero on 2014-02-06 12:00:04 UTC
