centralized place for all available gazebo plugins
Dear Friends, Is there any centralized place where all Gazebo plugins can be searched? Most of models do not come with plugins! I am attempting to launch Pioneer3at from ROS but missing plugins is one of the issues.
thanks nitin
Edit 1: I am using gazebo 1.9 precompiled which come with Ubuntu,
Error Error [SkidSteerDrivePlugin.cc:83] The
Asked by nitin on 2014-01-30 21:21:39 UTC
The Pioneer3at model uses the SkidSteerPlugin, which is included with gazebo. I have the gazebo-current
deb installed and I have the following files in my /usr folder:
$ find /usr | grep SkidSteer /usr/lib/x86_64-linux-gnu/gazebo-2.2/plugins/libSkidSteerDrivePlugin.so /usr/include/gazebo-2.2/gazebo/plugins/SkidSteerDrivePlugin.hh
You may not be able to find the plugins because they are not in a standard path location. There is a setup script for Gazebo that can help setup environment variables properly:
source /usr/share/gazebo/setup.sh
Can you provide console error messages if this doesn't help?
Asked by scpeters on 2014-01-31 19:46:36 UTC
Yes it did helped . i have updated the question. I will try to interface with ros using it.
Asked by nitin on 2014-02-12 21:08:06 UTC
for a catkin workspace you can add the following to the export region of your package.xml
of the package that launches gazebo:
<export>
<gazebo_ros gazebo_plugin_path="${prefix}/lib"/>
</export>
for me this works fine and all of my plugins are found.
Asked by evilBiber on 2014-02-04 07:38:15 UTC
thanks for reply but i do not where plugin are in my system. Are they even present or i need to download separately.
Asked by nitin on 2014-02-12 21:08:52 UTC
