Sourced Gazebo ROS pkg cannot compile
I am currently using Gazebo 1.9.3. I am trying to install the gazebo ros packages via source. I followed the tutorial for the ros hydro version (http://gazebosim.org/wiki/Tutorials/1.9/Installing_gazebo_ros_Packages#Install_gazebo_ros_pkgs).
When I get to building the gazebo ros package I get a error:
[100%] Building CXX object gazeborospkgs/gazeboroscontrol/CMakeFiles/gazeboroscontrol.dir/src/gazeboroscontrolplugin.cpp.o /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:471:3: error: ‘PositionJointSaturationInterface’ in namespace ‘jointlimitsinterface’ does not name a type /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:474:3: error: ‘VelocityJointSoftLimitsInterface’ in namespace ‘jointlimitsinterface’ does not name a type /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp: In member function ‘virtual void gazeboroscontrol::DefaultRobotHWSim::writeSim(ros::Time, ros::Duration)’: /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:274:5: error: ‘pjsatinterface’ was not declared in this scope /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:277:5: error: ‘vjlimitsinterface’ was not declared in this scope /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp: In member function ‘void gazeboroscontrol::DefaultRobotHWSim::registerJointLimits(const string&, const hardwareinterface::JointHandle&, gazeboroscontrol::DefaultRobotHWSim::ControlMethod, const ros::NodeHandle&, const urdf::Model, int, double, double, double)’: /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:426:19: error: ‘VelocityJointSoftLimitsHandle’ in namespace ‘jointlimitsinterface’ does not name a type /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:428:13: error: ‘vjlimitsinterface’ was not declared in this scope /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:428:49: error: ‘limitshandle’ was not declared in this scope /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:446:19: error: ‘PositionJointSaturationHandle’ in namespace ‘jointlimitsinterface’ does not name a type /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:448:13: error: ‘pjsatinterface’ was not declared in this scope /home/code8200/catkinws/src/gazeborospkgs/gazeboroscontrol/src/defaultrobothwsim.cpp:448:46: error: ‘sathandle’ was not declared in this scope make[2]: ** [gazeborospkgs/gazeboroscontrol/CMakeFiles/defaultrobothwsim.dir/src/defaultrobothwsim.cpp.o] Error 1 make[1]: *** [gazeborospkgs/gazeboroscontrol/CMakeFiles/defaultrobothwsim.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... Linking CXX shared library /home/code8200/catkinws/devel/lib/libgazeboroscontrol.so [100%] Built target gazeboroscontrol make: *** [all] Error 2 Invoking "make" failed
From what I can see the problem is that there are files missing from which this gazebo package expects to do something with. I checked to see if all my ros depencies where covered for this package and the rosdep command comes back with no problems. Any one know how to fix this issue?
Asked by mfran89 on 2014-02-07 12:51:35 UTC
