Set is_static through service call
Hey gang,
I'm currently wrestling with an annoying problem. I am trying to simulate putting new tires on a car in Gazebo. I have models of the Wheels, and the hubs which they sit on. Currently, there are three "studs" which line up with three matching holes on the Wheel.
When I spawn the wheel on the hub, it looks fine at first. However, the tire will slowly wiggle itself off of the hub, in about 30 seconds.
I am looking for a method to stop physical simulation on the Wheel through a python script, which I would run once the tire is lifted into place.
However, I can't find an appropriate service call to set the is_static property of a model. How can I achieve this?
Asked by Peaches491 on 2014-02-07 16:19:44 UTC
Are you using gazebo with ros?
Asked by scpeters on 2014-02-07 19:17:52 UTC
Yes. Version 2.0
Asked by Peaches491 on 2014-02-07 19:22:47 UTC
Gazebo currently doesn't have service calls.
You could write a model plugin that creates a ROS service. The service could then call SetStatic on the model.
Asked by nkoenig on 2014-02-21 14:16:59 UTC
