Calling /gazebo/reset_simulation breaks contact sensor output
I have a model loaded that has a collision sensor. When I echo the rostopic, I see the expected output. But when I call /gazebo/reset_simulation
, that output hangs for a long time -- up to a minute. This is despite the fact that it only takes 5 seconds to launch Gazebo and get the sensor output to start with.
I've made a simple proof of concept and uploaded the workspace to github.
To replicate,
- Download and catkin_init the workspace
roslaunch BREAKROS_gazebo BREAKROS.launch
- In another terminal,
rostopic echo /sensored_block_bumper
rosservice call /gazebo/reset_simulation
- You'll see that Gazebo actually resets itself pretty quickly, but the sensor output hangs.
Is there any way to speed this up? For my real project, it poses quite a problem. The robot will resume its movement after a reset long before the collision sensor goes up again.
Asked by Ben B on 2014-02-17 14:16:39 UTC
This sounds very similar to http://answers.gazebosim.org/question/5194/differential-drive-ros-plugin-stops-responding ,so might has the same cause.
Asked by Stefan Kohlbrecher on 2014-02-18 05:29:44 UTC
You might be right. I've submitted a ticket: https://github.com/ros-simulation/gazebo_ros_pkgs/issues/169
Asked by Ben B on 2014-02-18 16:40:53 UTC
