Error with gzserver: floating point exception
Hi everyone,
I'm completely new to the gazebo world that I need to use for a robot project. I am running on Ubuntu 13.10 (Saucy) and I'm trying to install the gazebo 2.0 following these instructions: http://gazebosim.org/wiki/2.0/install
Everything works fine until the I have to use the command:
gzserver
Indeed what I get in the terminal is as follow (the last few lines):
Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 131.215.30.237 Floating point exception (core dumped)
I saw another thread about this issue with no answer and it is quite old now.
I also tried to install an older version of gazebo (just to see), and when I use the command line :
sudo apt-get install gazebo
Which should install the 1.9 version, I get the following response.
Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: gazebo : Depends: sdformat (>= 1.4.7~) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I'm completely stuck right now and don't know what to do. I don't know if it is related to the current distrib of Ubuntu that has some trouble with gazebo of if it's something else. If you have any suggestions or even a solution I would appreciate it.
Thanks in advance.
Best regards.
Asked by Frenetique on 2014-02-19 23:02:47 UTC
I solved my problem as follow.
I now use Ubuntu 12.04.4 LTS. The non proprety drivers (the ones provided as open source with Ubuntu) were not able to run my CG, indeed it was not recognized and it was using the integrated graphic accelerator chipset of the motherboard I guess. So I installed the ATI drivers (non beta) and it worked.
The problem with Ubuntu 13.10 is that the drivers provided are not very effective yet (apparently).
So this issue was in this case effectively related to the AMD/ATI driver and still is I guess. Thanks for the people on the link provided by nkoenig, it took me on the good track.
Asked by Frenetique on 2014-02-21 21:50:12 UTC
Can you post a backtrace from gzserver?
Asked by nkoenig on 2014-02-20 12:35:10 UTC
