Error when installing from source on ubuntu 12.04
I am getting a building error when installing from source under ubuntu 12.04.
The error:
gazebo-2.2.1/interfaces/player/player.h:22:38: fatal error: libplayercore/playercore.h: No such file or directory
the header file is located here:
/usr/include/player-3.0/libplayercore/playercore.h
Same error appears for older versions as well, such as 1.8.0.
The command sudo apt-get remove libplayer* did not fixed it for me, as in the following answer.
Also, under ubuntu 12.04 sudo apt-get install libogre-1.8-dev does not work, maybe the install tutorials should be updated?
=============UPDATE===================
here is the issue on bitbucket
Asked by AndreiHaidu on 2014-03-09 11:54:00 UTC
have you tried using deb for installation. Deb package for version 2.2.1 is available as well !
Asked by nitin on 2014-03-10 00:34:34 UTC
thanks for the answer, the deb works just fine, I just needed the source installation ;)
Asked by AndreiHaidu on 2014-03-10 08:24:29 UTC
