Problem with echo of a message
I'm trying to do an echo of a message between gazebo and a external application with a custom message. I have no problem sending messages from the application to gazebo, but i can't return the message, and everytime that i try i receive this warning:
Warning [Publisher.cc:144] Queue limit reached for topic /gazebo/default/physics/contacts, deleting message. This warning is printed only once.
i don't understand what is the problem, if anyone has a solution i'll be very gratefull
here is the external application:
#include <iostream>
#include <sdf/sdf.hh>
#include "gazebo/gazebo.hh"
#include "gazebo/common/common.hh"
#include "gazebo/math/Vector3.hh"
#include "gazebo/transport/transport.hh"
#include "gazebo/physics/physics.hh"
#include "gazebo/msgs/msgs.hh"
#include "call_answer.pb.h"
#define MAX_WAITING 1500 //tempo espresso in centesimi di secondo
using namespace std;
typedef const boost::shared_ptr<const call_answer_msgs::msgs::Response> AnswerPtr;
void StampData(AnswerPtr &_msg);
int main(int argc, char * argv[])
call_answer_msgs::msgs::Request request;
request.set_answ(20);
// Initialize transport
gazebo::transport::init();
// Create our node for communication
gazebo::transport::NodePtr node(new gazebo::transport::Node());
node->Init();
// Start transport
gazebo::transport::run();
//invio la richiesta di temperatura
cout << "invio richiesta..." << endl;
gazebo::transport::PublisherPtr Req;
Req = node->Advertise<call_answer_msgs::msgs::Request>("~/MyRequest");
Req->WaitForConnection();
Req->Publish(request);
// Listen to Gazebo world_stats topic
gazebo::transport::SubscriberPtr sub = node->Subscribe("~/MyAnswer", StampData);
// Busy wait loop...replace with your own code as needed.
int i=0;
while (true && i < MAX_WAITING){
i++;
gazebo::common::Time::MSleep(10);
// Make sure to shut everything down
gazebo::transport::fini();
return 0;
cout << _msg->resp() << endl;
here the gazebo's plugin:
#include <iostream>
#include <vector>
#include <string>
#include <math.h>
#include <gazebo/gazebo.hh>
namespace gazebo
typedef const boost::shared_ptr<const call_answer_msgs::msgs::Request> ConstRequestPtr;
class MySensor : public ModelPlugin
transport::NodePtr node; //Nodo per la connessione
transport::SubscriberPtr commandSubscriber;
public: void Load(physics::ModelPtr _model, sdf::ElementPtr _sdf)
physics::WorldPtr world = _model->GetWorld();
//inizializzo il nodo
node = transport::NodePtr(new transport::Node());
node->Init(world->GetName());
std::cout << std::endl;
std::cout << "Subscribing to: " << "~/MyRequest" << std::endl;
commandSubscriber = node->Subscribe("~/MyRequest", &MySensor::create,this);
}//fine load
public: void create(ConstRequestPtr &msg)
std::cout << "รจ arrivato il messaggio: "<< msg->answ() << std::endl;
double val = msg->answ();
//invio il messaggio a ROS/eseguibile esterno
call_answer_msgs::msgs::Response answer;
answer.set_resp(val);
std::cout << "i'm here 1" << std::endl;
gazebo::transport::PublisherPtr tmprRes;
std::cout << "i'm here 2" << std::endl;
tmprRes = node->Advertise<call_answer_msgs::msgs::Response>("~/MyAnswer", 100);
std::cout << "i'm here 3" << std::endl;
tmprRes->WaitForConnection();
tmprRes->Publish(answer);
//else {
// std::cout << "messaggio non inviato" << std::endl;
}//fine create
GZ_REGISTER_MODEL_PLUGIN(MySensor)
Asked by Luigi on 2014-03-23 16:08:56 UTC
The following line in your external program:
should be:
void StampData(ConstAnswerPtr &_msg)
That may fix your problem.
Asked by nkoenig on 2014-03-25 13:28:00 UTC
I have tried but it doesn't change anything, moreover I tried with an integrated message in Gazebo and it keep giving me back the same warning (and didn't send me back the original message). In your opinion, are there any other errors?
Asked by Luigi on 2014-03-28 11:27:07 UTC
Take a look at the publisher and listener examples. They work, assuming you have gzserver running.
Asked by nkoenig on 2014-03-28 13:50:01 UTC
