Hokuyo not pubishing to ROS
I would like to publish laser scans, that are performed by e.g the Hokuyo Model in Gazebo to ROS. I have tried this with Fuerte and Hydro without success.
I used this materials: Gazebo 1.9 ROS Hydro Ubuntu 12.04
I then started Gazebo with this command
roslaunch gazebo_ros empty_world.launch
This then gives me these topics in ROS
rostopic list
/clock
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/set_link_state
/gazebo/set_model_state
/rosout
/rosout_agg
In Gazebo I added the Hokuyo model which is already included. I can see the scanarea indicated in blue. I can'T see any new topic in ROS. I can see in the model.sdf that it uses the libRayPlugin.so Plugin. Furthermore I noticed that a topic tag is missing inside the sensor tag. I added one. Still no publishing.Thas how the sensor section model.sdf of the Hokuyo looks like
  <sensor name="laser" type="ray">
        <pose>0.01 0 0.0175 0 -0 0</pose>
    <topic>~/laser_scan</topic>
        <ray>
          <scan>
            <horizontal>
              <samples>640</samples>
              <resolution>1</resolution>
              <min_angle>-2.26889</min_angle>
              <max_angle>2.268899</max_angle>
            </horizontal>
          </scan>
          <range>
            <min>0.08</min>
            <max>10</max>
            <resolution>0.01</resolution>
          </range>
        </ray>
        <plugin name="laser" filename="libRayPlugin.so" />
I tried different topics such as /laserscan, laserscan. Am I missing something?
BR & and thanks for any help
Asked by Eisenhorn on 2014-03-24 05:09:26 UTC
Ok I solved that problem. I cheanged the plugin to this /hokuyo_laser map
Asked by Eisenhorn on 2014-03-24 08:51:34 UTC
