Problem installing GAZEBO on ubuntu 12.10 (broken package)
Hey guys, i was trying to install gazebo in my ubuntu 12.0, following the steps in "gazebosim.org/wiki/1.2/install" . However, after i input
sudo apt-get install gazebo
in terminal as step 4 suggested, it shows up the following errors:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
gazebo : Depends: libboost-thread1.46.1 but it is not installable
Depends: libboost-signals1.46.1 but it is not installable
Depends: libboost-system1.46.1 but it is not installable
Depends: libboost-filesystem1.46.1 but it is not installable
Depends: libboost-program-options1.46.1 but it is not installable
Depends: libboost-regex1.46.1 but it is not installable
Depends: libboost-iostreams1.46.1 but it is not installable
Depends: libcegui-mk2-0.7.5 but it is not installable
Depends: sdformat (>= 1.4.7~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I've tried
sudo apt-get install -f
to fix it, but its still not working. Please, any suggestions or commnets will be appreciated XD
Eason.Lee
Could you please update the answer with the output of these commands: "ls /etc/apt/sources.list.d/" ,"apt-get install sdformat" and "apt-get install libboost-iostreams1.46-dev". Thanks.
