Debugging with gdb on Gazebo Roslaunch
Hi, i use ROS Hydro and Gazebo 1.9 on Ubuntu 13.04. I want to debug a Gazebo plugins compiled as a shared library wrote in C and inserted into the simulation. I would use gdb, and i would insert breakpoint, and son on. It's possibile to do this during the simulation? How can i do? I also read this page http://wiki.ros.org/roslaunch/Tutorials/Roslaunch%20Nodes%20in%20Valgrind%20or%20GDB But isn't enough clear.
Thanks
Asked by Stefano Aringhieri on 2014-04-02 16:58:21 UTC
There are some scripts in drcsim that enable this behavior. See the atlas_no_controllers.launch file and the scripts folder, especially run_gzserver_gdb. I believe it can be invoked by appending gzname:=gzserver_gdb to the roslaunch command, for example
roslaunch drcsim_gazebo atlas.launch gzname:=gzserver_gdb
Asked by scpeters on 2014-04-02 19:35:31 UTC
Thanks for you answer. But there is something similar to set a variable in the CmakeLists.txt of source's package of the library ? For example set(.....DEBUG =1 ) ?
Asked by Stefano Aringhieri on 2014-04-03 03:58:26 UTC
