gzfactory spawning issues
asked 2014-04-11 08:33:48 -0600
Carbon Based Lifeform gravatar image
updated 2014-04-11 11:00:33 -0600
Hello, whenever I try to spawn my robot model in the gazebo world from command line, typing
gzfactory spawn -f model.sdf -z 0.19
I get
Error [parser_urdf.cc:2608] Unable to call parseURDF on robot model
Error [parser.cc:273] parse as old deprecated model file failed.
Error: SDF parsing the xml failed
At first, I thought that this was caused by the fact that I had in the same folder my model.sdf and my model.urdf, so I moved the urdf file into another folder and retried. Same result. If I load the robot.urdf model, it successfully spawns with the requested offset, just to collapse into the ground after a few instants (might be a problem of collision?). If I load my robot.sdf file with a world plugin, everything is fine again, except that I would like to spawn with a global z offset and that's why I'm using gzfactory. (Of course the error occurs even if don't specify the offset). What's happening?
EDIT: I'm working with Gazebo 2.2
answered 2014-04-14 07:44:42 -0600
updated 2014-04-14 07:47:16 -0600
I'm using gazebo 1.9 but for me the script works fine... can you try using gzfactory with one of the models from the model database
I tried:
gzfactory spawn -f ~/.gazebo/models/beer/model-1_4.sdf -y -5.0
and it works fine...(you have to download the beer before you can use it ;) )
it is also possible to set the position of your model with the world plugin. The method SetWorldPose should do the trick here...
another thing you could do is loading the model using a world file
  <?xml version="1.0" ?>
  <sdf version="1.4">
      <world name="default">
        <uri>model://sun</uri>
      <!-- A ground plane -->
        <uri>model://gas_station</uri>
        <name>gas_station</name>
        <pose>-2.0 70.0 0 0 0 0</pose>
    </world>
this way you can specify a position to... i hope this helps
Thank you, I solved my problem by avoiding the gzfactory command, and by just using the <pose> offset in the model.sdf file.
Carbon Based Lifeform gravatar imageCarbon Based Lifeform ( 2014-04-14 11:17:42 -0600 )edit
Asked: 2014-04-11 08:33:48 -0600
Seen: 800 times
Last updated: Apr 14 '14
