drcsim-1.3 viz error
asked 2013-01-08 12:47:06 -0500
jarevalo gravatar image
updated 2013-01-09 15:37:52 -0500
nkoenig gravatar image
When following the tutorial Visualize and Log Sensor Data from drcsim-1.3 there is an error on viz that says No transform from imu link to pelvis. Plus the robot loads with no hands when running
roslaunch atlas_utils atlas_position_controllers.launch
Can you post the output of the roslaunch scipt?
nkoenig gravatar imagenkoenig ( 2013-01-09 15:38:50 -0500 )edit
answered 2013-01-09 18:42:55 -0500
hsu gravatar image
this should be addressed by issue #72
Thank you this solved the issue about the IMU
jarevalo gravatar imagejarevalo ( 2013-01-12 05:30:59 -0500 )edit
answered 2013-01-12 07:01:24 -0500
This is the roslaunch script, thanks for the help.
<launch>
<arg name="gzname" default="gazebo"/>
<include file="$(find atlas_utils)/launch/atlas_no_controllers.launch"> <arg name="gzname" value="$(arg gzname)"/> </include>
<include file="$(find pr2_controller_manager)/controller_manager.launch"/>
<node pkg="rostopic" type="rostopic" name="fake_joint_calibration" args="pub /calibrated std_msgs/Bool true"/>
<node pkg="tf2_ros" type="buffer_server" name="tf2_buffer_server" output="screen"> </node>
<rosparam file="$(find atlas)/ros/position_controllers.yaml" command="load"/>
<node name="atlas_controllers_spawner" pkg="pr2_controller_manager" type="spawner" output="screen" args="--wait-for=/calibrated l_arm_elx_position_controller r_arm_elx_position_controller l_arm_ely_position_controller r_arm_ely_position_controller l_arm_mwx_position_controller r_arm_mwx_position_controller l_arm_shx_position_controller r_arm_shx_position_controller l_arm_usy_position_controller r_arm_usy_position_controller l_arm_uwy_position_controller r_arm_uwy_position_controller l_leg_kny_position_controller r_leg_kny_position_controller l_leg_lax_position_controller r_leg_lax_position_controller l_leg_lhy_position_controller r_leg_lhy_position_controller l_leg_mhx_position_controller r_leg_mhx_position_controller l_leg_uay_position_controller r_leg_uay_position_controller l_leg_uhz_position_controller r_leg_uhz_position_controller neck_ay_position_controller back_lbz_position_controller back_mby_position_controller back_ubx_position_controller"/> </launch>
Asked: 2013-01-08 12:47:06 -0500
Seen: 124 times
Last updated: Jan 12 '13
