when build gazebo ,how to assign it to include ogre 1.8
Because I had installed ogre1.8, then, I installed ogre1.9 again.
Now ,when I build gazebo 2.0
It comes to an error
Bad Ogre3d version: gazebo using 1.9.0 ogre version has known bugs in runtime (issue #996). Please use 1.7 or 1.8 series
I don't know how to assign gazebo ogre 1.8
I tried to use cmake-gui to find if there is a name such as "ogre" "path"
but I could not find such name like that.
I also tried to enter:
export OGRE_HOME=/usr/local/ogre1.8
but it still didn't work
Thanks for help!
Asked by Zheng yo chen on 2014-05-19 19:11:02 UTC
Gazebo cmake system is looking for ogre via pkg-config. You could try something like:
export PKG_CONFIG_PATH=/home/foo/libogre-1.8/pkgconfig_directory:$PKG_CONFIG_PATH
or even pass it during cmake configuration phase:
cmake .. -DPKG_CONFIG_PATH=/home/foo/libogre-1.8/pkgconfig_directory:$PKG_CONFIG_PATH
Untested, just an idea.
Asked by Jose Luis Rivero on 2014-05-21 17:30:03 UTC
which ubuntu are you running? you might get it with apt-get
Asked by AndreiHaidu on 2014-05-20 06:44:31 UTC
I'm running ubutu 12.04. installing gazebo by "apt-get" may be one easy solution, but,I wan to know how to assign gazebo to a specific include. I think it's important to understand it. because ,maybe I'll face similar problem while build other software or library.
Asked by Zheng yo chen on 2014-05-20 21:54:36 UTC
sorry, i meant getting ogre with apt-get, but version 1.8 is not available that way in 12.04, you could try installing libogre-dev with apt-get, that will get you ogre-1.7.4-3 which suffices for gazebo
Asked by AndreiHaidu on 2014-05-21 01:46:53 UTC
