Gazebo 3.0 System Plugin Tutorial Crashing
asked 2014-05-20 04:35:37 -0600
Vineet gravatar image
Hi, I just installed Gazebo 3.0 from source and was doing all the tutorials in series. However I am stuck at the System Plugin tutorial.
After building the plugin here are the steps, 1) Launch gzserver in background using "gzserver & " 2) Launch gzclient using "gzclient -g libsystem_plugin.so", when I do this I get the following error -
gzclient: /usr/include/boost/smartptr/sharedptr.hpp:653: typename boost::detail::spmemberaccess<t>::type boost::sharedptr<t>::operator->() const [with T = gazebo::rendering::UserCamera; typename boost::detail::spmember_access<t>::type = gazebo::rendering::UserCamera*]: Assertion `px != 0' failed. Aborted (core dumped)
I searched but the only relevant discussion I could find is here. I am a beginner and too immature to understand that. Is there any way to solve this problem?
System Details: Gazebo 3.0 on Ubuntu 13.10, Latest ATI Catalyst Drivers
Code --
#include "gazebo/gui/GuiIface.hh" #include "gazebo/rendering/rendering.hh" #include "gazebo/gazebo.hh"
namespace gazebo { class SystemGUI : public SystemPlugin { public: virtual ~SystemGUI() { if (this->userCam) this->userCam->EnableSaveFrame(false); }
public: virtual void Load(int /*_argc*/, char ** /*_argv*/)
    private: virtual void Init()
    //this->updateConnection = event::Events::ConnectWorldUpdateBegin(boost::bind(&SystemGUI::OnUpdate, this, _1));
  // Get a pointer to the active user camera
  this->userCam = gui::get_active_camera();
  // Enable saving frames
  this->userCam->EnableSaveFrame(true);
  // Specify the path to save frames into
  this->userCam->SetSaveFramePathname("/home/vineet/.gazebo/gazebo_frames");
private: virtual void OnUpdate(const common::UpdateInfo & /*_info*/)
private: rendering::UserCameraPtr userCam;
private: std::vector<event::ConnectionPtr> connections;
GZREGISTERSYSTEM_PLUGIN(SystemGUI) }
answered 2014-05-20 06:41:39 -0600
AndreiHaidu gravatar image
Hi there,
The tutorial is kind of outdated. It crashes because the following code is ran before the rendering engine is initialized
To make sure you initialize the user camera after the engine has been initialized you should listen to the rendering events, and bind a callback function to it, for example:
void  MyPlugin::Init()
    // Initialize rendering related variables only when the rendering started
    this->updateConnection = event::Events::ConnectPreRender(
            boost::bind(&MyPlugin::InitAtRenderEvent, this));
this calls the following method, which initializes the user camera, at the first rendering event:
void MyPlugin::InitAtRenderEvent()
    // Set camera, can be set only after the rendering started
    // Listen to the update event.
    // This event is broadcast every simulation iteration.
    this->updateConnection = event::Events::ConnectRender(
            boost::bind(&MyPlugin::OnUpdate, this));
then the updateConnection is switched to call the OnUpdate method for every rendering event:
void MyPlugin::OnUpdate()
      //your code here
      std::cout << "Update" << std::endl;
Cheers, Andrei
Thanks, It worked.
Vineet gravatar imageVineet ( 2014-05-20 17:42:48 -0600 )edit
We should make an issue or pull request to fix the tutorial: https://bitbucket.org/osrf/gazebo_tutorials/issues?status=new&status=open
scpeters gravatar imagescpeters ( 2014-05-20 19:43:23 -0600 )edit
Asked: 2014-05-20 04:35:37 -0600
Seen: 712 times
Last updated: May 20 '14
