How to fix that failed to launch empty_world.launch on Hydro?
I use ROS Hydro with ubuntu 12.04.
I run:
sam@sam:~$ roslaunch gazebo_ros empty_world.launch
... logging to /home/sam/.ros/log/2a9a2cdc-e7d8-11e3-9bc9-20cf30a23845/roslaunch-sam-6178.log
Press Ctrl-C to interrupt
started roslaunch server http://sam:55890/
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
 * /use_sim_time
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
core service [/rosout] found
process[gazebo-1]: started with pid [6196]
process[gazebo_gui-2]: started with pid [6201]
Gazebo multi-robot simulator, version 1.9.5
Copyright (C) 2014 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
Aborted (core dumped)
[gazebo-1] process has died [pid 6196, exit code 134, cmd /opt/ros/hydro/lib/gazebo_ros/gzserver worlds/empty.world __name:=gazebo __log:=/home/sam/.ros/log/2a9a2cdc-e7d8-11e3-9bc9-20cf30a23845/gazebo-1.log].
log file: /home/sam/.ros/log/2a9a2cdc-e7d8-11e3-9bc9-20cf30a23845/gazebo-1*.log
How to solve it?
Thank you~
Asked by sam on 2014-05-30 04:56:23 UTC
If you just launch 'gazebo' without ROS, is the output the same?
Asked by Jose Luis Rivero on 2014-05-30 16:59:38 UTC
