Altering Scene.cc to Change Grid Size
asked 2014-07-23 16:26:24 -0500
K. Zeng gravatar image
This is a follow-up question to an earlier one I asked regarding changing grid size. Is there any way to access the Scene.cc file so I can change the hard-coded value of 20x20? I tried to use ls in the directory it's stored in, but all it showed were the .hh files.
answered 2014-07-24 19:55:51 -0500
scpeters gravatar image
You would need to build gazebo from source. Try these instructions. Then look in the gazebo/rendering folder for Scene.cc
I see. Thanks. I'll find an alternate method, then.
K. Zeng gravatar imageK. Zeng ( 2014-07-25 15:09:42 -0500 )edit
I suppose you could also write a GUI system plugin to modify the grid size
scpeters gravatar imagescpeters ( 2014-07-25 16:23:03 -0500 )edit
Asked: 2014-07-23 16:26:24 -0500
Seen: 758 times
Last updated: Jul 24 '14
