Error in opening a world with gazebo
When I tried to open my world with gazebo, gazebo src/coverage/coverage/worlds/willow-pr2-5cm.world
it said :
Error [parser_urdf.cc:2722] Unable to load file[/home/lempereur/catkin_ws/src/coverage/coverage/worlds/willow-pr2-5cm.world].
Error [parser.cc:278] parse as old deprecated model file failed
I can't understand what is my mistake
Asked by Moda on 2014-07-24 04:06:15 UTC
If you are using the this version of willow-pr2-5cm.world, that will not work with gazebo. It looks like a stage file, not a gazebo world file. Try this world instead.
Asked by scpeters on 2014-07-24 19:58:58 UTC
So I'm using groovy, which simulator should I use in order to open willow_pr2_5cm.world?
Asked by Moda on 2014-07-25 01:50:16 UTC
If you follow the instructions to install packages from packages.osrfoundation.org, then you can install ros-groovy-gazebo-ros-pkgs
. See the gazebo ros tutorials here
Asked by scpeters on 2014-07-25 12:31:40 UTC
