Gazebo Ros Spawn Baxter.urdf Error (rospack)
So I'm trying to spawn the Baxter urdf in Gazebo 1.9 the standard way following the online tutorial but I keep getting this error.
[INFO] [WallTime: 1406710618.379330] [0.000000] Loading model xml from file [INFO] [WallTime: 1406710618.383029] [0.000000] Waiting for service /gazebo/spawnurdfmodel [INFO] [WallTime: 1406710618.450412] [0.000000] Calling service /gazebo/spawnurdfmodel Service call failed: service [/gazebo/spawnurdfmodel] responded with an error:
Unhandled exception in thread started by sys.excepthook is missing lost sys.stderr
I get this^ in the terminal window where I put the rosrun command in:
rosrun gazeboros spawnmodel -file catkinws/src/baxtercommon/baxter_description/urdf/baxter.urdf -urdf -z 1 -model baxter
And I get the outputs below in the terminal window where roslaunch was run.
[rospack] Error: stack/package baxterdescription not found [librospack]: error while executing command [FATAL] [1406710620.095704066, 5133.064000000]: Package[baxterdescription] does not have a path
I have run source ~/catkin_ws/devel/setup.bash when I realised this might be it but it wasn't the problem. And gazebo is definitely running.
Any help would be fantastic. Thanks
Asked by Recelis on 2014-07-30 05:08:09 UTC
can you move to the directory by typing roscd baxter_description? It looks like this package is not installed correctly...
Asked by evilBiber on 2014-07-30 06:06:46 UTC
Thanks evilBiber. That was the problem, I didn't do make build for some stupid reason.Thanks a lot.
Asked by Recelis on 2014-07-30 22:12:40 UTC
