How to spawn a model on ROS Groovy Gazebo without falling down?
I use ROS Groovy and ubuntu 12.04.
I can successfully adding a table on gazebo.
I also can spawn a coke_can object stable without falling down on a table.
But when I spawn the testtubeshelf.urdf, it fall down everytime.
How to fix it?
Thank you~
The following is the details.
coke_can.urdf :
<robot name="coke_can_model">
<link name="coke_can">
<mass value="0.1" />
<!-- center of mass (com) is defined w.r.t. link local coordinate system -->
<origin xyz="0 0 0.06" />
<inertia ixx="0.1" ixy="0.0" ixz="0.0" iyy="0.1" iyz="0.0" izz="0.1" />
<visual>
<!-- visual origin is defined w.r.t. link local coordinate system -->
<origin xyz="0 0 -0.18" rpy="0 0 0" />
<mesh filename="package://sam_pr2_lab_auto_scene_6/urdf/coke_can.dae" scale="0.001 0.001 0.001" />
<collision>
<!-- collision origin is defined w.r.t. link local coordinate system -->
<gazebo reference="coke_can">
<material>Gazebo/Red</material>
<turnGravityOff>false</turnGravityOff>
<kp>100000000.0</kp>
<kd>1000000.0</kd>
</robot>
Here is the dae file link.
testtubeshelf.urdf :
<robot name="test_tube_shelf_model">
<link name="test_tube_shelf">
<visual>
<mesh filename="package://sam_pr2_lab_auto_scene_6/urdf/test_tube_shelf.dae" scale="0.1 0.1 0.1" />
<collision>
<gazebo reference=" test_tube_shelf ">
<kd>1000000.0</kd>
</robot>
testtubeshelf.dae :
<?xml version="1.0" encoding="utf-8"?>
<COLLADA xmlns="http://www.collada.org/2005/11/COLLADASchema" version="1.4.1">
<asset>
<contributor>
<author>Blender User</author>
<authoring_tool>Blender 2.65.0 r52859</authoring_tool>
</contributor>
<created>2014-07-25T10:15:56</created>
<modified>2014-07-25T10:15:56</modified>
<unit name="meter" meter="1"/>
<up_axis>Z_UP</up_axis>
</asset>
<library_images/>
<library_effects/>
<library_geometries>
<geometry id="Square_Rack-mesh" name="Square Rack">
<mesh>
<source id="Square_Rack-mesh-positions">
<float_array id="Square_Rack-mesh-positions-array" count="672">-17.625 -11.75 0 -17.625 -11.75 25 -17.625 11.75 0 -17.625 11.75 25 17.625 -11.75 0 17.625 -11.75 25 17.625 11.75 0 17.625 11.75 25 -10.79494 -11.29144 25 0.9550991 11.2914 25 10.7949 11.2914 25 -12.70507 -11.29144 25 -14.5 -10.63814 25 -17.25 -5.875 25 -16.91831 -7.75611 25 -2.75 -1.1119 25 -0.9550991 -0.4586 25 -7.5368 2.3397 25 -5.1683 -3.99389 25 -4.2132 -2.33967 25 -9 -1.1119 25 -5.5 -5.875 25 -6.5817 -3.99389 25 -16.91831 3.9939 25 -16.91831 -3.99389 25 -15.96324 -2.33967 25 -6.25 -5.875 25 -15.96324 2.3397 25 -14.5 -1.1119 25 9 -1.1119 25 9 1.1119 25 7.5368 2.3397 25 -14.5 1.1119 25 -12.70507 -0.4586 25 -12.70507 0.4586 25 -10.79494 -0.4586 25 5.168301 -3.99389 25 6.581699 -3.99389 25 4.2132 -2.33967 25 -10.79494 0.4586 25 6.581699 3.9939 25 6.25 5.875 25 5.5 5.875 25 10.7949 -11.29144 25 9 -10.63814 25 2.75 -10.63814 25 7.5368 -9.41033 25 6.581699 -7.75611 25 5.168301 -7.75611 25 0.9550991 -11.29144 25 -0.9550991 -11.29144 25 -15.96324 -9.41033 25 -17.25 5.875 25 6.581699 7.7561 25 7.5368 9.4103 25 5.168301 7.7561 25 -16.91831 7.7561 25 -4.2132 -9.41033 25 -5.1683 -7.75611 25 -6.5817 -7.75611 25 -6.5817 3.9939 25 -12.70507 11.2914 25 -14.5 10.6381 25 0.9550991 0.4586 25 2.75 -1.1119 25 -10.79494 11.2914 25 -2.75 10.6381 25 -9 10.6381 25 -7.5368 9.4103 25 -9 1.1119 25 -15.96324 9.4103 25 -6.25 5.875 25 -5.1683 3.9939 25 12.7051 -11.29144 25 -5.5 5.875 25 6.25 -5.875 25 5.5 -5.875 25 4.2132 -9.41033 25 14.5 -10.63814 25 0.9550991 -0.4586 25 -0.9550991 0.4586 25 -7.5368 -2.33967 25 -2.75 -10.63814 25 -9 -10.63814 25 -7.5368 -9.41033 25 -4.2132 2.3397 25 -2.75 1.1119 25 -6.5817 7.7561 25 -4.2132 9.4103 25 -5.1683 7.7561 25 2.75 10.6381 25 4.2132 9.4103 25 9 10.6381 25 12.7051 11.2914 25 14.5 10.6381 25 2.75 1.1119 25 -0.9550991 11.2914 25 7.5368 -2.33967 25 4.2132 2.3397 25 16.9183 -7.75611 25 15.9632 -9.41033 25 10.7949 0.4586 25 10.7949 -0.4586 25 5.168301 3.9939 25 15.9632 9.4103 25 16.9183 7.7561 25 12.7051 0.4586 25 12.7051 -0.4586 25 14.5 1.1119 25 14.5 -1.1119 25 15.9632 2.3397 25 15.9632 -2.33967 25 17.25 5.875 25 16.9183 -3.99389 25 17.25 -5.875 25 16.9183 3.9939 25 -16.91831 -7.75611 2 -17.25 -5.875 2 -15.96324 -9.41033 2 -14.5 -10.63814 2 -12.70507 -11.29144 2 -10.79494 -11.29144 2 -9 -10.63814 2 -7.5368 -9.41033 2 -6.5817 -7.75611 2 -6.25 -5.875 2 -6.5817 -3.99389 2 -7.5368 -2.33967 2 -9 -1.1119 2 -10.79494 -0.4586 2 -12.70507 -0.4586 2 -14.5 -1.1119 2 -15.96324 -2.33967 2 -16.91831 -3.99389 2 -16.91831 3.9939 2 -17.25 5.875 2 -15.96324 2.3397 2 -14.5 1.1119 2 -12.70507 0.4586 2 -10.79494 0.4586 2 -9 1.1119 2 -7.5368 2.3397 2 -6.5817 3.9939 2 -6.25 5.875 2 -6.5817 7.7561 2 -7.5368 9.4103 2 -9 10.6381 2 -10.79494 11.2914 2 -12.70507 11.2914 2 -14.5 10.6381 2 -15.96324 9.4103 2 -16.91831 7.7561 2 -5.1683 -7.75611 2 -5.5 -5.875 2 -4.2132 -9.41033 2 -2.75 -10.63814 2 -0.9550991 -11.29144 2 0.9550991 -11.29144 2 2.75 -10.63814 2 4.2132 -9.41033 2 5.168301 -7.75611 2 5.5 -5.875 2 5.168301 -3.99389 2 4.2132 -2.33967 2 2.75 -1.1119 2 0.9550991 -0.4586 2 -0.9550991 -0.4586 2 -2.75 -1.1119 2 -4.2132 -2.33967 2 -5.1683 -3.99389 2 -5.1683 3.9939 2 -5.5 5.875 2 -4.2132 2.3397 2 -2.75 1.1119 2 -0.9550991 0.4586 2 0.9550991 0.4586 2 2.75 1.1119 2 4.2132 2.3397 2 5.168301 3.9939 2 5.5 5.875 2 5.168301 7.7561 2 4.2132 9.4103 2 2.75 10.6381 2 0.9550991 11.2914 2 -0.9550991 11.2914 2 -2.75 10.6381 2 -4.2132 9.4103 2 -5.1683 7.7561 2 6.581699 -7.75611 2 6.25 -5.875 2 7.5368 -9.41033 2 9 -10.63814 2 10.7949 -11.29144 2 12.7051 -11.29144 2 14.5 -10.63814 2 15.9632 -9.41033 2 16.9183 -7.75611 2 17.25 -5.875 2 16.9183 -3.99389 2 15.9632 -2.33967 2 14.5 -1.1119 2 12.7051 -0.4586 2 10.7949 -0.4586 2 9 -1.1119 2 7.5368 -2.33967 2 6.581699 -3.99389 2 6.581699 3.9939 2 6.25 5.875 2 7.5368 2.3397 2 9 1.1119 2 10.7949 0.4586 2 12.7051 0.4586 2 14.5 1.1119 2 15.9632 2.3397 2 16.9183 3.9939 2 17.25 5.875 2 16.9183 7.7561 2 15.9632 9.4103 2 14.5 10.6381 2 12.7051 11.2914 2 10.7949 11.2914 2 9 10.6381 2 7.5368 9.4103 2 6.581699 7.7561 2</float_array>
<technique_common>
<accessor source="#Square_Rack-mesh-positions-array" count="224" stride="3">
<param name="X" type="float"/>
<param name="Y" type="float"/>
<param name="Z" type="float"/>
</accessor>
</technique_common>
</source>
<source id="Square_Rack-mesh-normals">
<float_array id="Square_Rack-mesh-normals-array" count="1332">-1 0 0 -1 0 0 0 -1 0 0 -1 0 0 0 -1 0 0 -1 0 1 0 0 1 0 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 1 0 0 1 0 0 0.9848078 0.1736478 0 0.9848078 0.1736478 0 0.866024 0.5000025 0 0.866024 0.5000025 0 0.6427895 0.7660429 0 0.6427895 0.7660429 0 0.3420197 0.9396928 0 0.3420197 0.9396928 0 0 1 0 0 1 0 -0.3420181 0.9396934 0 -0.3420181 0.9396934 0 -0.6427996 0.7660343 0 -0.6427996 0.7660343 0 -0.8660173 0.5000141 0 -0.8660173 0.5000141 0 -0.984807 0.1736529 0 -0.984807 0.1736529 0 -0.984807 -0.173653 0 -0.984807 -0.173653 0 -0.8660174 -0.500014 0 -0.8660174 -0.500014 0 -0.6427874 -0.7660446 0 -0.6427874 -0.7660446 0 -0.3420179 -0.9396935 0 -0.3420179 -0.9396935 0 0 -1 0 0 -1 0 0.3420195 -0.9396929 0 0.3420195 -0.9396929 0 0.6427772 -0.7660532 0 0.6427772 -0.7660532 0 0.8660241 -0.5000024 0 0.8660241 -0.5000024 0 0.9848079 -0.1736478 0 0.9848079 -0.1736478 0 0.9848076 0.1736487 0 0.9848076 0.1736487 0 0.8660214 0.500007 0 0.8660214 0.500007 0 0.6427865 0.7660454 0 0.6427865 0.7660454 0 0.3420195 0.9396929 0 0.3420195 0.9396929 0 0 1 0 0 1 0 -0.3420179 0.9396935 0 -0.3420179 0.9396935 0 -0.6427967 0.7660369 0 -0.6427967 0.7660369 0 -0.8660147 0.5000185 0 -0.8660147 0.5000185 0 -0.9848068 0.1736539 0 -0.9848068 0.1736539 0 -0.9848067 -0.1736538 0 -0.9848067 -0.1736538 0 -0.8660146 -0.5000187 0 -0.8660146 -0.5000187 0 -0.6427968 -0.7660369 0 -0.6427968 -0.7660369 0 -0.3420181 -0.9396934 0 -0.3420181 -0.9396934 0 0 -1 0 0 -1 0 0.3420197 -0.9396928 0 0.3420197 -0.9396928 0 0.6427866 -0.7660453 0 0.6427866 -0.7660453 0 0.8660213 -0.5000071 0 0.8660213 -0.5000071 0 0.9848076 -0.1736487 0 0.9848076 -0.1736487 0 0.984807 0.1736529 0 0.984807 0.1736529 0 0.8660173 0.5000141 0 0.8660173 0.5000141 0 0.6427996 0.7660343 0 0.6427996 0.7660343 0 0.3420246 0.939691 0 0.3420246 0.939691 0 0 1 0 0 1 0 -0.3420246 0.939691 0 -0.3420246 0.939691 0 -0.6427996 0.7660343 0 -0.6427996 0.7660343 0 -0.8660171 0.5000145 0 -0.8660171 0.5000145 0 -0.984807 0.1736524 0 -0.984807 0.1736524 0 -0.984807 -0.1736524 0 -0.984807 -0.1736524 0 -0.8660171 -0.5000144 0 -0.8660171 -0.5000144 0 -0.6427874 -0.7660446 0 -0.6427874 -0.7660446 0 -0.3420245 -0.9396911 0 -0.3420245 -0.9396911 0 0 -1 0 0 -1 0 0.3420245 -0.9396911 0 0.3420245 -0.9396911 0 0.6427874 -0.7660446 0 0.6427874 -0.7660446 0 0.8660174 -0.500014 0 0.8660174 -0.500014 0 0.984807 -0.173653 0 0.984807 -0.173653 0 0.9848068 0.1736539 0 0.9848068 0.1736539 0 0.8660147 0.5000185 0 0.8660147 0.5000185 0 0.6427967 0.7660369 0 0.6427967 0.7660369 0 0.3420245 0.9396911 0 0.3420245 0.9396911 0 0 1 0 0 1 0 -0.3420245 0.9396911 0 -0.3420245 0.9396911 0 -0.6427967 0.7660369 0 -0.6427967 0.7660369 0 -0.8660145 0.5000189 0 -0.8660145 0.5000189 0 -0.9848069 0.1736534 0 -0.9848069 0.1736534 0 -0.9848069 -0.1736533 0 -0.9848069 -0.1736533 0 -0.8660144 -0.5000191 0 -0.8660144 -0.5000191 0 -0.6427968 -0.7660369 0 -0.6427968 -0.7660369 0 -0.3420246 -0.939691 0 -0.3420246 -0.939691 0 0 -1 0 0 -1 0 0.3420246 -0.939691 0 0.3420246 -0.939691 0 0.6427968 -0.7660369 0 0.6427968 -0.7660369 0 0.8660146 -0.5000187 0 0.8660146 -0.5000187 0 0.9848067 -0.1736538 0 0.9848067 -0.1736538 0 0.984807 0.1736524 0 0.984807 0.1736524 0 0.8660171 0.5000145 0 0.8660171 0.5000145 0 0.6427996 0.7660343 0 0.6427996 0.7660343 0 0.3420248 0.939691 0 0.3420248 0.939691 0 0 1 0 0 1 0 -0.3420248 0.939691 0 -0.3420248 0.939691 0 -0.6427998 0.7660343 0 -0.6427998 0.7660343 0 -0.8660171 0.5000145 0 -0.8660171 0.5000145 0 -0.984807 0.1736527 0 -0.984807 0.1736527 0 -0.984807 -0.1736527 0 -0.984807 -0.1736527 0 -0.8660171 -0.5000144 0 -0.8660171 -0.5000144 0 -0.6427875 -0.7660445 0 -0.6427875 -0.7660445 0 -0.3420247 -0.9396911 0 -0.3420247 -0.9396911 0 0 -1 0 0 -1 0 0.3420247 -0.9396911 0 0.3420247 -0.9396911 0 0.6427874 -0.7660446 0 0.6427874 -0.7660446 0 0.8660171 -0.5000144 0 0.8660171 -0.5000144 0 0.984807 -0.1736524 0 0.984807 -0.1736524 0 0.9848069 0.1736534 0 0.9848069 0.1736534 0 0.8660145 0.5000189 0 0.8660145 0.5000189 0 0.6427967 0.7660369 0 0.6427967 0.7660369 0 0.3420247 0.9396911 0 0.3420247 0.9396911 0 0 1 0 0 1 0 -0.3420247 0.9396911 0 -0.3420247 0.9396911 0 -0.6427968 0.7660368 0 -0.6427968 0.7660368 0 -0.8660145 0.5000189 0 -0.8660145 0.5000189 0 -0.9848068 0.1736536 0 -0.9848068 0.1736536 0 -0.9848067 -0.1736536 0 -0.9848067 -0.1736536 0 -0.8660144 -0.5000191 0 -0.8660144 -0.5000191 0 -0.6427969 -0.7660368 0 -0.6427969 -0.7660368 0 -0.3420248 -0.939691 0 -0.3420248 -0.939691 0 0 -1 0 0 -1 0 0.3420248 -0.939691 0 0.3420248 -0.939691 0 0.6427968 -0.7660369 0 0.6427968 -0.7660369 0 0.8660144 -0.5000191 0 0.8660144 -0.5000191 0 0.9848069 -0.1736533 0 0.9848069 -0.1736533 0 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1 0 0 1</float_array>
<technique_common>
<accessor source="#Square_Rack-mesh-normals-array" count="444" stride="3">
</accessor>
</technique_common>
</source>
<vertices id="Square_Rack-mesh-vertices">
<input semantic="POSITION" source="#Square_Rack-mesh-positions"/>
</vertices>
<polylist count="444">
<input semantic="VERTEX" source="#Square_Rack-mesh-vertices" offset="0"/>
<input semantic="NORMAL" source="#Square_Rack-mesh-normals" offset="1"/>
<vcount>3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 </vcount>
<p>0 0 1 0 2 0 2 1 1 1 3 1 1 2 0 2 4 2 5 3 1 3 4 3 0 4 2 4 4 4 4 5 2 5 6 5 2 6 3 6 6 6 6 7 3 7 7 7 8 8 1 8 5 8 9 9 10 9 7 9 11 10 12 10 1 10 13 11 1 11 14 11 15 12 16 12 17 12 3 13 1 13 13 13 18 14 19 14 20 14 21 15 18 15 22 15 23 16 24 16 25 16 22 17 26 17 21 17 27 18 25 18 28 18 29 19 30 19 31 19 32 20 28 20 33 20 34 21 33 21 35 21 36 22 37 22 38 22 39 23 35 23 20 23 40 24 41 24 42 24 43 25 44 25 45 25 46 26 47 26 48 26 49 27 50 27 5 27 11 28 1 28 8 28 27 29 23 29 25 29 51 30 1 30 12 30 14 31 1 31 51 31 52 32 24 32 23 32 34 33 32 33 33 33 3 34 24 34 52 34 53 35 54 35 55 35 52 36 56 36 3 36 57 37 58 37 59 37 60 38 17 38 16 38 61 39 3 39 62 39 7 40 3 40 61 40 37 41 63 41 64 41 7 42 61 42 65 42 66 43 67 43 68 43 69 44 20 44 17 44 39 45 34 45 35 45 70 46 62 46 3 46 71 47 60 47 72 47 73 48 43 48 5 48 72 49 74 49 71 49 26 50 59 50 58 50 17 51 20 51 19 51 17 52 19 52 15 52 47 53 75 53 76 53 36 54 76 54 75 54 77 55 45 55 44 55 78 56 73 56 5 56 16 57 79 57 80 57 32 58 27 58 28 58 69 59 39 59 20 59 18 60 20 60 81 60 44 61 46 61 77 61 50 62 82 62 83 62 50 63 8 63 5 63 82 64 57 64 84 64 83 65 8 65 50 65 85 66 72 66 60 66 84 67 83 67 82 67 60 68 16 68 86 68 76 69 48 69 47 69 87 70 71 70 74 70 63 71 79 71 64 71 88 72 68 72 89 72 90 73 91 73 92 73 93 74 94 74 7 74 9 75 90 75 10 75 37 76 95 76 63 76 7 77 65 77 96 77 63 78 80 78 79 78 7 79 96 79 9 79 97 80 29 80 98 80 99 81 100 81 5 81 101 82 30 82 102 82 87 83 89 83 68 83 74 84 89 84 87 84 65 85 67 85 96 85 88 86 66 86 68 86 16 87 80 87 86 87 41 88 53 88 55 88 60 89 86 89 85 89 29 90 31 90 103 90 64 91 38 91 37 91 104 92 105 92 7 92 98 93 95 93 97 93 103 94 98 94 29 94 106 95 102 95 107 95 108 96 107 96 109 96 110 97 109 97 111 97 112 98 111 98 113 98 7 99 114 99 5 99 7 100 113 100 114 100 75 101 37 101 36 101 45 102 49 102 43 102 43 103 49 103 5 103 58 104 21 104 26 104 59 105 84 105 57 105 100 106 78 106 5 106 42 107 103 107 40 107 55 108 42 108 41 108 92 109 10 109 90 109 94 110 104 110 7 110 10 111 93 111 7 111 91 112 55 112 54 112 66 113 96 113 67 113 54 114 92 114 91 114 106 115 101 115 102 115 110 116 108 116 109 116 7 117 112 117 113 117 115 118 111 118 112 118 115 119 110 119 111 119 108 120 106 120 107 120 105 121 112 121 7 121 114 122 99 122 5 122 40 123 103 123 31 123 13 124 24 124 3 124 37 125 97 125 95 125 48 126 77 126 46 126 81 127 22 127 18 127 56 128 70 128 3 128 29 129 102 129 30 129 5 130 4 130 6 130 7 131 5 131 6 131 13 132 14 132 116 132 117 133 13 133 116 133 14 134 51 134 118 134 116 135 14 135 118 135 12 136 119 136 51 136 51 137 119 137 118 137 11 138 120 138 12 138 12 139 120 139 119 139 8 140 121 140 11 140 11 141 121 141 120 141 83 142 122 142 8 142 8 143 122 143 121 143 84 144 123 144 83 144 83 145 123 145 122 145 59 146 124 146 84 146 84 147 124 147 123 147 26 148 125 148 59 148 59 149 125 149 124 149 26 150 22 150 125 150 125 151 22 151 126 151 22 152 81 152 126 152 126 153 81 153 127 153 127 154 81 154 20 154 128 155 127 155 20 155 128 156 20 156 35 156 129 157 128 157 35 157 129 158 35 158 33 158 130 159 129 159 33 159 130 160 33 160 28 160 131 161 130 161 28 161 131 162 28 162 25 162 132 163 131 163 25 163 132 164 25 164 24 164 133 165 132 165 24 165 133 166 24 166 13 166 117 167 133 167 13 167 52 168 23 168 134 168 135 169 52 169 134 169 23 170 27 170 136 170 134 171 23 171 136 171 32 172 137 172 27 172 27 173 137 173 136 173 34 174 138 174 32 174 32 175 138 175 137 175 39 176 139 176 34 176 34 177 139 177 138 177 69 178 140 178 39 178 39 179 140 179 139 179 17 180 141 180 69 180 69 181 141 181 140 181 60 182 142 182 17 182 17 183 142 183 141 183 71 184 143 184 60 184 60 185 143 185 142 185 71 186 87 186 143 186 143 187 87 187 144 187 87 188 68 188 144 188 144 189 68 189 145 189 145 190 68 190 67 190 146 191 145 191 67 191 146 192 67 192 65 192 147 193 146 193 65 193 147 194 65 194 61 194 148 195 147 195 61 195 148 196 61 196 62 196 149 197 148 197 62 197 149 198 62 198 70 198 150 199 149 199 70 199 150 200 70 200 56 200 151 201 150 201 56 201 151 202 56 202 52 202 135 203 151 203 52 203 21 204 58 204 152 204 153 205 21 205 152 205 58 206 57 206 154 206 152 207 58 207 154 207 82 208 155 208 57 208 57 209 155 209 154 209 50 210 156 210 82 210 82 211 156 211 155 211 49 212 157 212 50 212 50 213 157 213 156 213 45 214 158 214 49 214 49 215 158 215 157 215 77 216 159 216 45 216 45 217 159 217 158 217 48 218 160 218 77 218 77 219 160 219 159 219 76 220 161 220 48 220 48 221 161 221 160 221 76 222 36 222 161 222 161 223 36 223 162 223 36 224 38 224 162 224 162 225 38 225 163 225 163 226 38 226 64 226 164 227 163 227 64 227 164 228 64 228 79 228 165 229 164 229 79 229 165 230 79 230 16 230 166 231 165 231 16 231 166 232 16 232 15 232 167 233 166 233 15 233 167 234 15 234 19 234 168 235 167 235 19 235 168 236 19 236 18 236 169 237 168 237 18 237 169 238 18 238 21 238 153 239 169 239 21 239 74 240 72 240 170 240 171 241 74 241 170 241 72 242 85 242 172 242 170 243 72 243 172 243 86 244 173 244 85 244 85 245 173 245 172 245 80 246 174 246 86 246 86 247 174 247 173 247 63 248 175 248 80 248 80 249 175 249 174 249 95 250 176 250 63 250 63 251 176 251 175 251 98 252 177 252 95 252 95 253 177 253 176 253 103 254 178 254 98 254 98 255 178 255 177 255 42 256 179 256 103 256 103 257 179 257 178 257 42 258 55 258 179 258 179 259 55 259 180 259 55 260 91 260 180 260 180 261 91 261 181 261 181 262 91 262 90 262 182 263 181 263 90 263 182 264 90 264 9 264 183 265 182 265 9 265 183 266 9 266 96 266 184 267 183 267 96 267 184 268 96 268 66 268 185 269 184 269 66 269 185 270 66 270 88 270 186 271 185 271 88 271 186 272 88 272 89 272 187 273 186 273 89 273 187 274 89 274 74 274 171 275 187 275 74 275 75 276 47 276 188 276 189 277 75 277 188 277 47 278 46 278 190 278 188 279 47 279 190 279 44 280 191 280 46 280 46 281 191 281 190 281 43 282 192 282 44 282 44 283 192 283 191 283 73 284 193 284 43 284 43 285 193 285 192 285 78 286 194 286 73 286 73 287 194 287 193 287 100 288 195 288 78 288 78 289 195 289 194 289 99 290 196 290 100 290 100 291 196 291 195 291 114 292 197 292 99 292 99 293 197 293 196 293 114 294 113 294 197 294 197 295 113 295 198 295 113 296 111 296 198 296 198 297 111 297 199 297 199 298 111 298 109 298 200 299 199 299 109 299 200 300 109 300 107 300 201 301 200 301 107 301 201 302 107 302 102 302 202 303 201 303 102 303 202 304 102 304 29 304 203 305 202 305 29 305 203 306 29 306 97 306 204 307 203 307 97 307 204 308 97 308 37 308 205 309 204 309 37 309 205 310 37 310 75 310 189 311 205 311 75 311 41 312 40 312 206 312 207 313 41 313 206 313 40 314 31 314 208 314 206 315 40 315 208 315 30 316 209 316 31 316 31 317 209 317 208 317 101 318 210 318 30 318 30 319 210 319 209 319 106 320 211 320 101 320 101 321 211 321 210 321 108 322 212 322 106 322 106 323 212 323 211 323 110 324 213 324 108 324 108 325 213 325 212 325 115 326 214 326 110 326 110 327 214 327 213 327 112 328 215 328 115 328 115 329 215 329 214 329 112 330 105 330 215 330 215 331 105 331 216 331 105 332 104 332 216 332 216 333 104 333 217 333 217 334 104 334 94 334 218 335 217 335 94 335 218 336 94 336 93 336 219 337 218 337 93 337 219 338 93 338 10 338 220 339 219 339 10 339 220 340 10 340 92 340 221 341 220 341 92 341 221 342 92 342 54 342 222 343 221 343 54 343 222 344 54 344 53 344 223 345 222 345 53 345 223 346 53 346 41 346 207 347 223 347 41 347 116 348 118 348 119 348 121 349 116 349 120 349 120 350 116 350 119 350 122 351 116 351 121 351 123 352 116 352 122 352 124 353 116 353 123 353 125 354 116 354 124 354 126 355 116 355 125 355 127 356 116 356 126 356 128 357 116 357 127 357 129 358 116 358 128 358 130 359 116 359 129 359 131 360 116 360 130 360 132 361 116 361 131 361 133 362 116 362 132 362 117 363 116 363 133 363 134 364 136 364 137 364 139 365 134 365 138 365 138 366 134 366 137 366 140 367 134 367 139 367 141 368 134 368 140 368 142 369 134 369 141 369 143 370 134 370 142 370 144 371 134 371 143 371 145 372 134 372 144 372 146 373 134 373 145 373 147 374 134 374 146 374 148 375 134 375 147 375 149 376 134 376 148 376 150 377 134 377 149 377 151 378 134 378 150 378 135 379 134 379 151 379 152 380 154 380 155 380 157 381 152 381 156 381 156 382 152 382 155 382 158 383 152 383 157 383 159 384 152 384 158 384 160 385 152 385 159 385 161 386 152 386 160 386 162 387 152 387 161 387 163 388 152 388 162 388 164 389 152 389 163 389 165 390 152 390 164 390 166 391 152 391 165 391 167 392 152 392 166 392 168 393 152 393 167 393 169 394 152 394 168 394 153 395 152 395 169 395 170 396 172 396 173 396 175 397 170 397 174 397 174 398 170 398 173 398 176 399 170 399 175 399 177 400 170 400 176 400 178 401 170 401 177 401 179 402 170 402 178 402 180 403 170 403 179 403 181 404 170 404 180 404 182 405 170 405 181 405 183 406 170 406 182 406 184 407 170 407 183 407 185 408 170 408 184 408 186 409 170 409 185 409 187 410 170 410 186 410 171 411 170 411 187 411 188 412 190 412 191 412 193 413 188 413 192 413 192 414 188 414 191 414 194 415 188 415 193 415 195 416 188 416 194 416 196 417 188 417 195 417 197 418 188 418 196 418 198 419 188 419 197 419 199 420 188 420 198 420 200 421 188 421 199 421 201 422 188 422 200 422 202 423 188 423 201 423 203 424 188 424 202 424 204 425 188 425 203 425 205 426 188 426 204 426 189 427 188 427 205 427 206 428 208 428 209 428 211 429 206 429 210 429 210 430 206 430 209 430 212 431 206 431 211 431 213 432 206 432 212 432 214 433 206 433 213 433 215 434 206 434 214 434 216 435 206 435 215 435 217 436 206 436 216 436 218 437 206 437 217 437 219 438 206 438 218 438 220 439 206 439 219 439 221 440 206 440 220 440 222 441 206 441 221 441 223 442 206 442 222 442 207 443 206 443 223 443</p>
</polylist>
</mesh>
<extra><technique profile="MAYA"><double_sided>1</double_sided></technique></extra>
</library_geometries>
<library_visual_scenes>
<visual_scene id="Scene" name="Scene">
<node id="Square_Rack" name="Square_Rack" type="NODE">
<translate sid="location">0 -2.353208 0</translate>
<rotate sid="rotationZ">0 0 1 0</rotate>
<rotate sid="rotationY">0 1 0 0</rotate>
<rotate sid="rotationX">1 0 0 0</rotate>
<scale sid="scale">0.1 0.1 0.1</scale>
<instance_geometry url="#Square_Rack-mesh"/>
</node>
</visual_scene>
</library_visual_scenes>
<scene>
<instance_visual_scene url="#Scene"/>
</scene>
</COLLADA>
I spawn coke_can.urdf by:
rosrun gazebo spawn_model -urdf -file `rospack find sam_pr2_lab_auto_scene_6`/urdf/coke_can.urdf -model coke_can_1 -x 0.7 -z 0.6
I spawn testtubeshelf.urdf by:
rosrun gazebo spawn_model -urdf -file `rospack find sam_pr2_lab_auto_scene_6`/urdf/test_tube_shelf.urdf -model test_tube_shelf -x 0.7 -z 1.0
Asked by sam on 2014-08-02 06:10:06 UTC
