How to locate missing files reported by cmake while building OGRE
Problem with missing files Cmake & OGRE
I am trying to follow the instructions here http://gazebosim.org/wiki/Requirements to install the prerequesites before installing Gazebo.
I am working with a clean machine running Ubuntu 12.04 LTS.
I have been able to download and install the following software without much difficulties. 1. PROTOBUF 2. TINYXML 3.TBB 4. Boost 5. CEGUI
I downloaded version OGRESDKvc10v1-7-4 and have created a build directory.
I have sucessfully followed the instructions on http://www.ogre3d.org/tikiwiki/tiki-index.php?page=Prerequisites&tikiversion=Linux for other libraries to be downloaded and installed.
I downloaded and installed cmake version 2.8.12.2 I also installed cmake-gui. When I try to build OGRE by passing its directory path to cmake it returns the following error message. CMake Error at CMakeLists.txt:63 (include): include could not find load file:
OgreConfigTargets
CMake Error at CMakeLists.txt:106 (find_package): Could not find module FindOGRE.cmake or a configuration file for package OGRE.
Adjust CMAKEMODULEPATH to find FindOGRE.cmake or set OGRE_DIR to the directory containing a CMake configuration file for OGRE. The file will have one of the following names:
OGREConfig.cmake ogre-config.cmake
CMake Error at CMakeLists.txt:107 (find_package): Could not find module FindOIS.cmake or a configuration file for package OIS.
Adjust CMAKEMODULEPATH to find FindOIS.cmake or set OIS_DIR to the directory containing a CMake configuration file for OIS. The file will have one of the following names:
OISConfig.cmake ois-config.cmake
CMake Error: File /home/ashok/Ogre3d1.7.4/OgreSDKvc10v1-7-4/plugins.cfg does not exist. CMake Error at CMakeLists.txt:197 (configurefile): configurefile Problem configuring file
CMake Error: File /home/ashok/Ogre3d1.7.4/OgreSDKvc10v1-7-4/resources.cfg does not exist. CMake Error at CMakeLists.txt:198 (configurefile): configurefile Problem configuring file
CMake Error: File /home/ashok/Ogre3d1.7.4/OgreSDKvc10v1-7-4/samples.cfg does not exist. CMake Error at CMakeLists.txt:199 (configurefile): configurefile Problem configuring file
CMake Error: File /home/ashok/Ogre3d1.7.4/OgreSDKvc10v1-7-4/quakemap.cfg does not exist. CMake Error at CMakeLists.txt:200 (configurefile): configurefile Problem configuring file
CMake Error at Samples/BSP/CMakeLists.txt:11 (ogreconfigsamplelib): Unknown CMake command "ogreconfigsamplelib".
Configuring incomplete, errors occurred!
I do not know where to find the missing files.
Googling shows that there are files with same name on the internet but they appear to be released by some game companies and may not be what I need for Gazebo. Guidance is needed for completing the OGRE build. Regards Ashok
