gzclient Segfault Breaking Gazebo User Interface
Hello Community,
I am having trouble with my Gazebo user interface. When I first boot my computer, Gazebo works fine, and will load a blank map when I ask it to. However, if I ever restart Gazebo for any reason (close out and start again, etc.), the user interface glitches out. Instead of seeing a gridded map as usual, the gazebo screen appears black. I can still insert models and delete models and edit the environment, I just can't see what I'm doing.
When I run dmesg in the terminal, I get this line that I suspect is the root of the problem:
[ 605.908616] gzclient[2329]: segfault at 4 ip b6adada9 sp bff9b8a0 error 4 in libQtGui.so.4.8.1[b64d9000+aaa000]
EDIT:
I tried logging out and logging back into my user, then running gazebo, and got this error:
Gazebo multi-robot simulator, version 1.9.5
Copyright (C) 2014 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Msg Waiting for master
Msg Publicized address: 134.197.42.190
X Error of failed request: BadDrawable (invalid Pixmap or Window parameter)
Major opcode of failed request: 137 (DRI2)
Minor opcode of failed request: 3 (DRI2CreateDrawable)
Resource id in failed request: 0x3400002
Serial number of failed request: 28
Current serial number in output stream: 30
gzclient: /usr/include/boost/smart_ptr/shared_ptr.hpp:418: T* boost::shared_ptr<T>::operator->() const [with T = gazebo::transport::Connection]: Assertion `px != 0' failed.
Can anyone tell me what the problem is and how to fix it, or at least give me some leads on how to solve this?
Thanks, skyguyjedi
Asked by skyguyjedi on 2014-08-21 15:32:48 UTC
