Creating a custom message. Compile error: PROTOBUF_PROTOC_EXECUTABLE-NOTFOUND: not found
Hi
I'm trying to learn how to build my own messages and to that end I'm looking at this tutorial.
After following the tutorial and copying the code into into the appropriate files I try to compile but get an error. The following is the output of cmake ..; make:
-- The C compiler identification is GNU 4.8.2
-- The CXX compiler identification is GNU 4.8.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- system
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.26")
-- checking for module 'gazebo'
-- found gazebo, version 4.0.0
-- checking for module 'sdformat'
-- found sdformat, version 2.0.1
-- Looking for include file pthread.h
-- Looking for include file pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found PROTOBUF: /usr/lib/x86_64-linux-gnu/libprotobuf.so
-- Configuring done
-- Generating done
-- Build files have been written to: /home/nicolas/collision_map_creator/build
[ 10%] Running C++ protocol buffer compiler on /usr/include/gazebo-4.0/gazebo/msgs/proto/time.proto
/bin/sh: 1: PROTOBUF_PROTOC_EXECUTABLE-NOTFOUND: not found
make[2]: *** [msgs/time.pb.cc] Error 127
make[1]: *** [msgs/CMakeFiles/collision_map_creator_msgs.dir/all] Error 2
make: *** [all] Error 2
You wouldn't think following that tutorial would leave any room to make mistakes, but apparently I managed to do so anyway.
Can someone tell me what goes wrong and how I can fix it?
Thanks, Nick
Asked by NickDP on 2014-09-17 19:13:07 UTC
