Using SDF tags in URDF (gazebo extension) directly?
This questions is related to the previous thread: urdf-to-sdf-conversion [1].
Now, I'm reporting my observations when trying to use SDF tags from sdf1.4 in the URDF directly.
As mentioned in [1], it should be possible to use SDF within the gazebo tags referencing a link or joint within the URDF directly.
SDF tags for links
For setting most of the SDF tags relevant for links, URDF does not need the gazebo extensions, i.e. pose
, ìnertial
, visual
and collision
related tags are correctly set up using urdf-xml-link.
gravity
andself_collide
It's the same result as mentioned in this issuekinematic
It is converted to sdf. But seems to have no effect according to this threadvelocity_decay
The following can be used to setvelocity_decay
of a link.
With this, it's possible to set different values forlinear
andangular
(in contrast to using the gazebo tagdampingFactor
).<gazebo reference="${name}_base_link"> <velocity_decay> <linear>0.2</linear> <angular>0.4</angular> </velocity_decay> </gazebo>
SDF tags for joints
Similar to the above mentioned, tags that can correctly be set up using urdf-xml-joint are not considered here.
damping
andfriction
(dynamics)
damping
of anaxis
can only be set using the URDF tagdynmaics -> damping
All the following variants are not converted into the SDF file:<gazebo reference="${name}_1_joint"> <axis> <dynamics> <damping>0.7</damping> <friction>0.7</friction> </dynamics> </axis> <dynamics> <damping>0.6</damping> <friction>0.6</friction> </dynamics> <damping>0.5</damping> <friction>0.5</friction> </gazebo>
friction
cannot be set from anywhere as it is currently (not yet) supported (see PullRequest)physics
forode
(ode)
Both following variants are not converted into the SDF file:<gazebo reference="${name}_1_joint"> <provide_feedback>true</provide_feedback> <cfm_damping>true</cfm_damping> <fudge_factor>80</fudge_factor> <cfm>81</cfm> <erp>82</erp> <bounce>83</bounce> <max_force>84</max_force> <velocity>85</velocity> <limit> <cfm>86</cfm> <erp>87</erp> </limit> <suspension> <cfm>88</cfm> <erp>89</erp> </suspension> <physics> <ode> <provide_feedback>true</provide_feedback> <cfm_damping>true</cfm_damping> <fudge_factor>90</fudge_factor> <cfm>91</cfm> <erp>92</erp> <bounce>93</bounce> <max_force>94</max_force> <velocity>95</velocity> <limit> <cfm>96</cfm> <erp>97</erp> </limit> <suspension> <cfm>98</cfm> <erp>99</erp> </suspension> </ode> </physics> </gazebo>
Thus, it seems that using SDF tags directly within a URDF file is not supported - at least the way I tried to use them. In case I used them in the wrong way, please let me know! I'd be happy to test again then...
The only tags that are converted into the SDF file are gravity
, self_collide
(however, not considered due to issue), kinematic
(however, see thread) and velocity_decay
Asked by Felix on 2014-09-20 06:22:18 UTC
Considering the friction, this works for me :
<gazebo reference="link2">
<mu1>0.2</mu1>
<mu2>0.2</mu2>
Some examples are explained here
Asked by mehdi on 2015-06-17 05:00:46 UTC
Are you sure that these values are even set? Even with ROS kinetic and gazebo 7.8 there is now chance. Check it with gz model -m <your model name> -i
Asked by tik0 on 2017-06-20 20:59:56 UTC
Hi there,
i know this feed is a little outdated but i currently have issues when trying to go from xacro->urdf->sdf into gazebo. I have a fairly complex setup and need to change friction of models in my simulation.
Currently in my xacro i set up a wheel like this:
> <link name="wheel_f_l">
> <collision name="collision">
> <geometry>
> <cylinder radius="${wheel_radius}"
> length="${wheel_length}"/>
> </geometry>
> </collision>
> <visual name="visual">
> <geometry>
> </geometry>
> </visual>
> <xacro:solid_cylinder_inertial
> radius="${wheel_radius}" height="${wheel_length}"
> mass="${wheel_mass}" gcx="${0}" gcy="${0}" gcz="${0}"/>
> </link>
I then create a reference like this:
<gazebo reference="wheel_r_l">
<mu1>100</mu1>
<mu2>100</mu2>
<maxContacts>1</maxContacts>
but for some reason my parameters dont survive the conversion to sdf via. gz sdf -p test.urdf > test.sdf.
I should mention i am using ODE and want to create a "realistic" wheel.
Help would very much be appreciated!
Asked by Franzisdrak on 2016-09-22 05:43:30 UTC
For the friction and damping there is something in URDF, explained here http://wiki.ros.org/urdf/Tutorials/Adding%20Physical%20and%20Collision%20Properties%20to%20a%20URDF%20Model but it doesn't seem to affect my links as they keep sliding.
Asked by mehdi on 2015-06-17 04:45:49 UTC
