Gazebo not running even after installation
The following error shows up:
Error opening log file: "/root/.gazebo/gzserver.log" Error opening log file: "/root/.gazebo/default.log" Error opening log file: "/root/.gazebo/gzclient.log" Error opening log file: "/root/.gazebo/default.log" X Error of failed request: BadRequest (invalid request code or no such operation) Major opcode of failed request: 154 (GLX) Minor opcode of failed request: 19 (X_GLXQueryServerString) Serial number of failed request: 12 Current serial number in output stream: 12
Asked by samvrit on 2014-09-21 04:09:37 UTC
Have you tried:
source /opt/ros/your-ros-version/setup.bash
before executing gazebo?
I had that issue once and it was because I was not sourcing the correct bash file.
Asked by Alberto Romay on 2014-09-24 02:44:56 UTC
Sourcing ROS should not have anything to do when fixing standalone gazebo.
Asked by Jose Luis Rivero on 2014-09-30 18:40:43 UTC
What version of Gazebo are you using, and how did you install gazebo?
Asked by nkoenig on 2014-09-22 17:47:08 UTC
