ft_sensor plugin - does it work? zero force/torque published
Does the ft_sensor plugin works currently? I am trying it on Gazebo 4.0, it seems to be set up correctly, but it always publishes a zero value, both for force and torque.
This is an extract from the .sdf file I use:
https://gist.github.com/clynamen/de7a403643bdb508d505#file-gistfile1-txt
(I linked a gist since the code format does not seem to work)
If it does work for you, can you give your configuration or point me out another test case?
Asked by clynamen on 2014-10-18 16:20:47 UTC
It seems that, as for Gazebo 4.0.0, the
Here the fixed gist:
https://gist.github.com/clynamen/441b41efcc643039ff89
with --verbose a warning is issued when the
Asked by clynamen on 2014-10-18 17:07:17 UTC
