Error in different computer for gpu_ray max_range
I have a problem with gpuray sensor for ROS Indigo integration. Currently we have multiple PCs with the exact same Gazebo version 2.2.1. We have the same exact ROS Indigo. We have installed gazeboros_packages.
So, I have succesfully created a .xacro Pioneer robot model which has gpuray sensor, and all works well. But when I try the exact same model on another PC, the gpuray sensor somehow "does not" detect the maximum range of the sensor (I have tried debugging via RVIZ, the sensor only work on min_range).
Success in PC A:
image description
Failure in PC B, C, etc image description
<gazebo reference="front_sonar_box2">
        <sensor type="gpu_ray" name="front_sonar_box2">
        <pose>0 0 0 0 0 0</pose>
            <update_rate>40</update_rate>                               <!--update rate-->
            <ray>
                <scan>
                        <horizontal>
                            <samples>30</samples>               <!--ray -->
                            <resolution>1</resolution>
                            <min_angle>-0.131</min_angle>           <!-- -${field_of_view/2} -->
                            <max_angle>0.131</max_angle>        <!-- -${field_of_view/2} -->
                        </horizontal>
                </scan>
                <range>
                        <min>0.08</min>
                        <max>10</max>
                        <resolution>0.01</resolution>
                </range>
            <noise>
                    <type>gaussian</type>
                    <mean>0.0</mean>
                    <stddev>0.01</stddev>
                </noise>
            </ray>
        <plugin name="gazebo_ros_front_sonar_controller" filename="libgazebo_ros_gpu_laser.so">
                <topicName>/pioneer/sonar/scan2</topicName>
                <frameName>front_sonar_box2</frameName>
The error is: other PC seems can not "read" the maximum range. (The error also the same for RRBot example with gpu_ray sensor)
I am wondering if anyone has some solution regarding this glitch? Any tips and help is really appreciated, thanks before!
Asked by Rinaldo Otniel on 2014-11-07 11:24:31 UTC
I've the same problem using a SDF model :(
Asked by SailAvid on 2015-02-22 12:27:55 UTC
It is because your GPU is not supported by the gpu_ray scan simulator. It is as easy as changing gpu_ray to ray and libgazebo_ros_gpu_laser.so to libgazebo_ros_laser.so in your urdf file...
Unfortunately currently there are no clear error msgs pointing to this as the cause of your issue...
Good luck!
Asked by koenlek on 2015-03-13 04:01:24 UTC
