"save as" feature not saving light info into world file
I added a custom Point Light
on Gazebo GUI and save it via save as
but the resulted sdf
file only contain sun
with default setting. I can't either seem to save the default sun
with modification. Is saving light info not possible yet?
Gazebo 2.2.3 on Ubuntu Trusty 64b
Thanks.
I am also running into same problem. Anyone know answer to this? None of the three light sources save. It might be because they are not technically 'models'?
It seems that this issue has been solved from Gazebo 4.0. I just tried it out on 4.0.2: added some lights with the GUI, changed their colours and poses, and saved the world. When I loaded the world everything was alright.
Do you know if its a seemless upgrade from gazebo 2.2 --> 4.x when involving ros plugins?
Here is our changelog and migration guide.
